engine wont turn off with ignition off and key out (HELP) - JeepForum.com
post #1 of 8 Old 02-06-2011, 04:14 PM Thread Starter
deercopse
first it started last week after a snow storm i woke up one morning and the wipers were on all by them self with no key in ingnition i had to pull the big 20amp metal fuse by the pass feet the fuse panel there and i could turn wipers off by turning the wipers to high or low they would turn off. then yesterday we got more snow just a dusting my wife started it cause the light on odometer was on and the aps light and check engine light was on even with the key not in it someone noticed it all on and told her so she started it for a min so batt wouldnt die and she couldnt get the engine to turn off even with the ignition off and key out she tried jigling it and doing it back and forth to get it off but it wouldnt turn off. She ended up calling me and i told her to pull the fuel relay and then it ran out of gas. i figure its the ignition but not sure dont want to just start replacing things and fall into a money pit i dont have very much money im unemployed and want to see if any one else had this problem or know what it might be so it dont turn into a money pit which i aint got. Thanks
deercopse is offline
post #2 of 8 Old 02-06-2011, 05:21 PM
wushaw
Rockin jeep
wushaw's Avatar
Ign switch or the mechanicals to the ign switch are broke.
wushaw is offline
post #3 of 8 Old 02-06-2011, 09:42 PM
Ahrnsbrak14
take what you can apart and look inside, make sure no wires are sliced or disconnected, as far as turning it off, pull the gas line but have something to plug it like a screwdriver (its gana shoot a lot of gas out if not)
Ahrnsbrak14 is offline
post #4 of 8 Old 02-08-2011, 12:28 PM
overblown
Are you serious? You are telling him to pull of a pressurized gas line to kill the engine? Thats not smart at all. Just pull the fuse jeez.
overblown is offline
post #5 of 8 Old 02-08-2011, 03:43 PM
keepishop
1989 XJ Cherokee
Or cover the intake.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #6 of 8 Old 02-08-2011, 08:03 PM
Ahrnsbrak14
Ha **** good point.. Had the same kinda problem on my friends truck.. doing that would have been way easier..
post #7 of 8 Old 02-08-2011, 08:04 PM
Ahrnsbrak14
cant that hurt it in any way?
post #8 of 8 Old 02-09-2011, 11:49 AM
keepishop
1989 XJ Cherokee
An engine needs fuel, air, compression, and spark. So far we've covered cutting fuel, and cutting air. It's a bit difficult to cut out compression, but you could kill spark pretty easily. Either unplug the coil (It will possibly shock you), or unplug the ECU.
That probably covers all the bases, other than the diesel guys and spraying a co2 fire extinguisher down the intake.
Bleed or Quit.
AMP wont turn on!! mattdodd20 Audio, CB & Ham Radios, GPS, & Electrical 5 06-07-2010 07:43 PM
Ignition trouble, won't turn over natesh Audio, CB & Ham Radios, GPS, & Electrical 7 07-28-2009 12:55 PM
So, my CD player wont turn on.... GroundClearance Audio, CB & Ham Radios, GPS, & Electrical 3 04-03-2006 10:07 AM
HUB lock wont turn hillbillyrig General Jeep & Off-Road Equipment 2 02-10-2003 10:20 PM
