Engine wash car will not start - JeepForum.com
post #1 of 12 Old 05-05-2013, 09:49 PM Thread Starter
korro5
2005 WK
Engine had hard start and will rev to 2000 RPM not above ,put through scanner code showing PO698 ,PO600,PO340,PO403 and PO107 reads I think the water went thro ECM or ECU ,will I be needing a new ECu or can it be repair please help am new to the forum also all fuses and wire connection had been dried and spray with WD40.
korro5 is offline
post #2 of 12 Old 05-06-2013, 06:24 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Start by checking your Cam Position Sensor (P0340) and go from there. There are some things under the hood of a Jeep that don't like water.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 12 Old 08-29-2013, 09:14 AM Thread Starter
korro5
2005 WK
still having issue with my jeep after changing the cam position sensor the jeep revir to normal but with only one of the fuel rail sensor wiring on, if the second rail sensor wire is plugged back the engine will stop and after scan its reading PO600, thanks in advance your help appreciated
korro5 is offline
post #4 of 12 Old 10-29-2013, 12:51 PM Thread Starter
korro5
2005 WK
fuel rail regulator sensor
grand cherokee 2005 diesel 3.0L CRD laredo. after having water damaged, cam shaft sensor change the car starts and its drivable for a short journey and it will stall, now we discover unplugging the second fuel rail sensor, the car is drivable for miles with only the main fuel rail sensor and can go up to more than 90mph but if you need accelerate quick in a short distance the car wont respond, the engine management lights are on. please any help or suggestions that will be helpful will be very appreciated.
korro5 is offline
post #5 of 12 Old 10-30-2013, 12:08 AM
JohnCrabtree
1994 ZJ
This is why I NEVER wash under the hood. Some people say "Ahhh, I do it all the time! Nothing goes wrong!" but it only takes once.
Honestly, with electrical issues like that (caused by water damage) you should just get a dealer**** to diagnose it. You'll spend hours and hours trying to figure it out and you'll spend hundreds of dollars throwing parts at it without the right diagnostic tools and knowledge.
JohnCrabtree is offline
post #6 of 12 Old 10-30-2013, 02:59 PM
overland_HO
2013 WK
I have washed under the hood on all my past and current vehicles at-least once per year, never had a problem yet. When the vehicle's engine is cool, I use a light spray with some light de-greaser, I cover electronics/fuse box's with bags/towels and just slowly and carefully go over it all. I do agree with the above comment of getting it to the dealer to diagnose the codes and other problems because as mentioned you could spend lots and lots of time and money!
Sorry to hear about the damage and problems to your Jeep!
13 TrailHawk|HEMI|RubiRimsw/32"BFG MT|Intake
14 Silverado 3500|DMax|Allision|Z71|Tuned
overland_HO is offline
post #7 of 12 Old 10-30-2013, 03:10 PM
JohnCrabtree
1994 ZJ
Originally Posted by overland_HO
I have washed under the hood on all my past and current vehicles, never had a problem yet. When the vehicle's engine is cool, I use a light spray with some light de-greaser, I cover electronics/fuse box's with bags/towels and just slowly and carefully go over it all. I do agree with the above comment of getting it to the dealer to diagnose the codes and other problems because as mentioned you could spend lots and lots of money! Sorry to hear about the damage and problems to your Jeep!
Again, it only takes one time where you don't completely cover a connector and then you're screwed.
post #8 of 12 Old 10-30-2013, 03:43 PM
overland_HO
2013 WK
Yes you are correct and I agree with that!^
post #9 of 12 Old 10-31-2013, 09:51 AM Thread Starter
korro5
2005 WK
i wish i could take your advice to take the car to a main dealer this car is in a third world country theres no main dealers for jeep. Three quarters of time we buy these car in europe and ship it to africa but i knew about the electronics with these cars so i bought a scanner that would work the car and also because i can always get the spare parts from here europe or america, we scanned and this are the readings PO 473 sensor c reference vlotage circuit low+++,PO 087 fuel rail/system pressure too low, PO 600 Serial comm link malfunction. So we need someone who can interpret this codes so we can get the right parts to fix the car, help appreciated or any suggestion.
korro5 is offline
post #10 of 12 Old 11-08-2013, 08:15 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
No interior serial communications in your PCM or in street lingo....you have 'smoked' your PCM;
http://www.dtcsearch.com/P0600/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #11 of 12 Old 11-09-2013, 05:37 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If it were me in your situation, I would unplug every connector I could find in the engine bay, spray it out with contact cleaner, and reconnect it.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #12 of 12 Old 11-10-2013, 11:52 AM
KickboxingSloth
Distributer?
Eat. Sleep. Jeep. Repeat -O|||||||||O-
Eat Sleep Jeep Repeat -O|||||||O-
If you aint from Texas you aint ****!!! :)
KickboxingSloth is offline
