engine vibration when at a constant speed - JeepForum.com
post #1 of 10 Old 01-27-2013, 04:44 PM Thread Starter
mhaddox
2009 JK Wrangler
I have a 2009 Jeep wrangler. I've had it 10 months, in the last few weeks i noticed a slight engine vibration, which has gotten worse over the past few weeks. It vibrates whenever i am going at a constant speed, regardless of the speed, 10 mph, 30 mph or over 60. it does not vibrate when accelerating, or when my foot is off the gas. I am going to go have the tires balanced this week, but it seems like something else??
mhaddox is offline
post #2 of 10 Old 01-29-2013, 10:07 AM
Evildriver-3
You have a engine vibe at speeds but not when sitting in neutral and changing the rpm ? Try and explain this with more detail
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 10 Old 01-29-2013, 02:55 PM Thread Starter
mhaddox
2009 JK Wrangler
ok. The engine only vibrates when at a constant speed, it happens at around 20mph and faster. it doesnt matter what speed i go, 25, 35, 40, 50, etc... it vibrates just the same no matter what the speed. But it doesnt vibrate when sitting idle, it doesnt vibrate while i accelarate. and it doesnt vibrate when my foot is off the gas. what i am doing now to avoid the vibration is accelarate to the speed limit, then let it slow down alittle then i speed back up, and so on. One friend on mine told me that it was the tires, and another said it was the U joints.
mhaddox is offline
post #4 of 10 Old 01-29-2013, 02:59 PM
Evildriver-3
Ok what happens if it's in park and you hold it at 1800 or 2100 ?
]=Supershafts=[
post #5 of 10 Old 01-29-2013, 02:59 PM
Evildriver-3
Sounds motor related, maybe a vacuum leak or something
]=Supershafts=[
post #6 of 10 Old 01-30-2013, 10:19 AM
WJ-Jray73
2003 WJ
Easy way to eliminate engine vs. drivetain drive down a hill (no turns) when the vibration is going good, slide it into nuetral and kill the engine if its still vibrating you have a drivetrain/tire issue
03 WJ 4.7 Laredo Daily
04 WJ 4.0 Laredo Project
99 Wj 4.0 Laredo Doner
01 Wj 4.7 Limited Project
WJ-Jray73 is offline
post #7 of 10 Old 01-31-2013, 03:32 PM
Evildriver-3
Thats easier than starting it up in the driveway and holding it at 1800 rpm or whatever rpm right in the driveway ??
]=Supershafts=[
post #8 of 10 Old 02-03-2013, 10:10 AM
jokerchief462
Motor mounts, trans mounts, u=joints, driveshaft pout of balance, pinion angle from lift. It could be a ton of things so the suggestion on how to isolate is your starting point.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #9 of 10 Old 02-04-2013, 04:37 PM Thread Starter
mhaddox
2009 JK Wrangler
Took it down to the dealer to get a diagnostic. They determined that the front CV boot was damaged. They also came up with a list of other small things that need to be fixed. They did tell me to go get an alignment and have the tires balanced.
thanks everyone!
mhaddox is offline
post #10 of 10 Old 02-04-2013, 05:43 PM
Sycoglitch
Happy you found the issue
01' Limited I6, C8.25, D30, NP231, 3" Zone AAL Lift, Extended Shackles and relocators, Hella H4 E-code headlights w/ HD Wiring Harness, Fully Swayless, Front JKS Disco'd when needed, 60mm Bored TB, IRO LCA, Rear Disc Conversion
Sycoglitch is offline
