engine temp problem!!!!!! - JeepForum.com
post #1 of 2 Old 04-03-2012, 03:32 PM Thread Starter
ferrante33
could i get any help as to why my wrangler is doing this and where the sensor is for the gauge on a 2.5 inline 4 thats a 5speed stick thanks someone.the gauge moves by not off 100f
ferrante33 is offline
post #2 of 2 Old 04-03-2012, 11:24 PM
jnicewan
Engine temp problems can be a number of things and sometimes its multiple things. The temp guage sender is located at the rear of engine where the intake manifold meets the cyl head and right beside the valve cover. The sender screws in and has a single wire connector thats purple with a yellow stripe.
If it seems like the engine is running erratic temps you should check the coolant level & condition and flush the cooling system if neccesary. Test and/or replace the thermostat, make sure the cooling fan clutch is good and functioning correctly, make sure the A/C condensor and radiator are clean and free of debris.
jnicewan is offline
problems , temp gauge , temp sensor , wranger
engine temp a little high CarolinaZJ Engines & Drivetrain 5 03-26-2012 06:56 PM
difference coolant temp & engine temp? Hussler Engines & Drivetrain 4 11-29-2010 09:31 PM
Normal 4.0 Engine Temp JRussum Engines & Drivetrain 3 08-23-2007 12:27 PM
Engine Temp mstngdtb Engines & Drivetrain 2 08-24-2006 05:18 PM
Engine temp on 304 Bulletproofcj7 Engines & Drivetrain 2 04-12-2002 11:35 PM
