Engine temp issue - JeepForum.com
post #1 of 3 Old 02-10-2012, 05:53 AM Thread Starter
MikeA85
I got a p1281 code a few weeks ago. Changed the thermostat, 195 degree as recommended. Code cleared ok it's own now it's back. What's up with that?
MikeA85 is offline
post #2 of 3 Old 02-12-2012, 10:45 AM
chris142
Either a faulty new thermostat or the housing is pitted and allowing coolant to bypass the thermostat.
You didn't use one of those failsafe ones from Vatozone did you?
chris142 is offline
post #3 of 3 Old 05-08-2014, 02:10 PM
LAX_TJ
Same Problem
I'm dealing with a nearly identical issue. I'm needing to get my 02 TJ inspected and because I'm in Houston, cant bypass the CEL issue. I haven't tried a fix yet because I just now narrowed down the issue to a temp. thing. Temp warms up on my gauge as it should so no sensor issue that I can figure; code says engine stays cold too long. which is total crap. My mechanic (this seemed weird to me) suggested I turn the thermostat 180 degrees and it should fix the problem. Given his previous credibility with me on my annoying jeep fixes, he does know what he's talking about, but has anyone else ever heard of this? Am I just the idiot who doesn't see how this would affect anything?
LAX
LAX_TJ is offline
