engine swap time - JeepForum.com
post #1 of 5 Old 05-03-2004, 10:14 AM Thread Starter
meg888
meg888's Avatar
engine swap time
Anybody done an engine swap on a 95 wrangler? I'm getting ready to drop in an '88 cherokee 6 cylinder and would like to have a heads up to any problems anybody else came across. Any good write-ups anywhere would be nice to! Thanks
'95 White Wrangler, 2.5L 4cyl.(but just got my hands on an XJ 6cyl that will be in soon!), 3.5 inch susp. lift and 2inch body, 33x12.50 Interco Trxus MT Tires, 15x10 Eagle 589 wheels, and other modifications inside and out
meg888 is offline
post #2 of 5 Old 05-03-2004, 10:23 AM
BowtieXJ
Uh oh. Man, I hope you don't get the same beating I just got...
I'm looking for the same info on an engine swap in an XJ...
BowtieXJ is offline
post #3 of 5 Old 05-03-2004, 09:00 PM
79cj360
try google..................
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
re quick disconnects
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
international dana 70 front w/closed knuckles
" damn modification bug bit me hard, so im bittin back!!"
"Go mud or go home"
79cj360 is offline
post #4 of 5 Old 05-04-2004, 09:03 AM
75SV1
If you have emmission checks in your state, dropping in an older engine is a no-no. Not sure on off road vehicles.
I see a bunch of potential problems. First is motor mounts. In 88 the Wrangler used the 4.2. I am not sure if the 88 motor has the bosses needed for the Wrangler. I bought a 95 motor out of a Wrangler. They guy had an '00 out of a Cherokee. He said he couldn't use it, because the motor mounts wouldn't bolt up. I compared it to my '03 out of a GC. The front bosses were not drilled and tapped on the '03 block. I'll try and check tonight and compare the '88 block in my Comanche.
You would need to source a wiring harness and ECM for the correct year(let say 95), tranny type(auto or stick), and 4WD or 2WD. If you already have an auto tranny, I'd check Advance Adapters website for info.
You would also need the flywheel and crankshaft position sensor for the year you are converting to.
If you have a manual tranny, I think its an AX-5. I am not sure if/how it would bolt up to the 4.0.
There are a lot of website with conversions in the Wrangler. You really need to think this through. Plus you might need to source or modify your tachometer. Since yours is a 4 banger, the counting sensor is different for a 6.
Tom
75SV1 is offline
post #5 of 5 Old 05-05-2004, 06:56 AM
prossett
prossett's Avatar
Location: The oasis city of Al Ain, where the red sand dunes of the UAE meet the craggy mountains of Oman
http://www.novak-adapt.com/knowledge...ge_gateway.htm
International Jeep Club, Member No. 1 - Canadian living in the United Arab Emirates
White Jeep Club Member 33
prossett is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
4.0l swap ? (time sensitive, so please hurry) mintt Engines & Drivetrain 5 11-21-2009 06:09 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Time for a differential swap KYCatinSC Engines & Drivetrain 4 11-28-2008 11:31 PM
4.0L radiator fan replacement, about how much time to swap it? TJSilverSport02 Engines & Drivetrain 0 06-01-2004 10:34 PM
