Engine swap problems - JeepForum.com
post #1 of 1 Old 07-28-2005, 03:33 PM Thread Starter
butrfly002
Trying to put a rebuilt engine from a 78 Jeep manual transmission (not sure exactly what it came out of) into a 1983 AMC Eagle automatic (orginal engine was 258 in³ (4.2 L) inline-6. It featured an undersquare 3.75 in (95 mm) bore and 3.90 in (99 mm) stroke. Features computerized engine control system). Replacement engine seems to be identical to the original engine from the Eagle (except lacking a hole in the short block to screw a vertical hanger that runs between engine and differential). With all the other support is the extra hanger essential it was unhooked from the original engine and doesn't seem to provide any real support? I have: removed the clutch and flywheel from the new engine. I installed the flex plate from the old engine, but can't figure out how to install the torque converter from the old engine. It won't fit into the bellhousing. It is the same torque converter that came out of the housing it doesn't seem like it should be so difficult to put back in. The manual says I need a special tool to put it in?
The Chiltons manual says:
To install:
21. If the torque converter is removed, insert Pump Aligning Tool J-24033 (Models 904-998), J-24045 (Model 727) or other equivalents into the pump.
22. Engage the pump rotor.
23. Rotate the tool until the drilled holes in the tool are vertical.
24. Remove the tool.
25. Rotate the converter until the pump drive slots are vertical, and carefully install the converter into pump.
We are thinking this is why we can't get the torque converter to go back into the housing. What is this tool and is it possible to install the torque converter without it? If not where can we get one? We may need a new coverter since it is the original but it seems we just can't get the alignment right (other cars we've worked on it seems the coverter will just slide into the bellhousing).
Last edited by butrfly002; 07-29-2005 at 11:14 AM. Reason: addtional info/clarification
butrfly002 is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
engine problems tippmann243 Engines & Drivetrain 11 04-02-2007 06:04 PM
2.8l Problems, Swap to 3.4L? pdye Engines & Drivetrain 4 08-05-2003 08:26 PM
engine swap problems lXl Rebel Wrangler lXl Engines & Drivetrain 5 11-14-2002 11:53 PM
