Engine swap - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Engine swap
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 11-01-2002, 08:53 PM   #1
double8
Engine swap
does anyone know if it is possible to put a Ford straight 6 in a 82 cj what modifications would be needed . this is an older 6 cyl with carb--very simple--no pollution crap thanks
double8 is offline   Reply With Quote
Unread 11-01-2002, 09:46 PM   #2
jeepdaddy2000
1971 CJ5
Why would you want to use a Ford 6? Stock Jeep motors are easy to come by and much easier to install. Anyway, is it a 176/200 or a 240/300 CID. The 200 should fit without much trouble. The 300 is quite a bit longer. It is possable that you will have to push the fire wall back.You will have to mesure the length and compare it to the engine bay. This is beyond the motor mounts, carb,cluch, trans, and other misc adaptions.
jeepdaddy2000 is offline   Reply With Quote
Unread 11-02-2002, 05:24 PM   #3
double8
engine swap
just trying to get a simple to work on engine.ive got a 66 ford with 240 engine .very basic--eng.,carb,alt-thats it . would like a setup like it in my jeep---can it be done with a jeep eng.?? i dont need pollution crap on it where i live
Unread 11-05-2002, 09:55 AM   #4
2point8
1986 XJ Cherokee
just curious, where do you live? im in California, so i cant even put on chrome valve covers without failing emissions!
86 XJ, 2.8, 5 spd 3" lift
235/75/15's
Edelbrock valve covers
Flowmaster dual exit muffler
TBI swap: 1228062 ECM, 4.3 TB. GM 14054884 Heads. Comp Cams k16-232-4, 0.425" Valve lift
2point8 is offline   Reply With Quote
Unread 11-05-2002, 05:19 PM   #5
double8
pollution crap
I live in southwest fla. no pollution checks here yet. moved from miami where the pollution checks were just one of many problems!!!
Unread 11-06-2002, 06:33 AM   #6
artsound
Miami stopped emissions inspection in 2000
artsound is offline   Reply With Quote
