Engine Swap - JeepForum.com
post #1 of 2 Old 10-02-2012, 04:06 PM Thread Starter
pwelch
Engine Swap
I have a 2006 Wrangler SE with the 2.4L inline 4 cylinder engine. The engine blew due to a failed oil pan gasket while my girlfriend drove it to the Adirondack's without a clue.
My question is how much would I have to change to put a 6 cylinder engine like this in it? Probably not worth it I know but I would like to know.
Thanks
pwelch is offline
post #2 of 2 Old 10-05-2012, 12:52 PM
jjmoonen
That is a big chunk of change for a reman engine imho. For that kind of money you could find a good lower mileage used option to throw in and get some performance goodies on top of it.
Yeah you could absolutely swap it in, but its not a yank the old drop in the new swap (engine swaps never are). You didnt mention what Trans. you have, but odds are very good its not going to hold up to the I6. SO you would have to get a trans that could hold up in that regard (the ax-15 or the one of the autos used for the 6 bangers depending on whether you have an auto of manual now). Then you may also be looking at different drive shaft lengths and changing the mounting locations of the trans and t-case mounts. Then there is cooling, the radiator will need to be upgraded to deal with the larger more powerful engine. Plus all the little stuff that may or may not need to be changed (throttle linkages and such).
Guys do it all the time but it is something you definitely need to do your homework on. Then when your done doing tons of research and you think you have all your bases covered, then the surprises show up.
I say do it, especially if the 4 popper puked its guts. No better time to add power.
Moondog
If it wont go...force it.
jjmoonen is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
Hemi vs LS (Not talking Swap) Just Engine vs Engine - Who is #1 Transamman Engines & Drivetrain 14 05-11-2014 02:46 AM
help please - engine swap - engine upgrade jwood883 Engines & Drivetrain 1 09-11-2012 05:09 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
