Engine swap - JeepForum.com
post #1 of 11 Old 09-21-2012, 05:39 PM Thread Starter
blakebentley
Engine swap
Hello,
I have a 2008 wrangler unlimited. I got a Chevy 400 small block that I wanna put in. I can figure out the mechanical aspects any day, but the electrical/computer wiring is what gets me. What do I do with all the wiring thatwillnot connect to a older motor? Any tips would be greatly appreciated
blakebentley is offline
post #2 of 11 Old 09-21-2012, 07:18 PM
tjkj2002
2002 KJ Liberty
1st it's a illegal swap.You must use a engine from the same year or newer then the vehicle it's going into and all the emission stuff must be tranfered over as well.
2nd you'd loose everything controlled by the PCM and BCM(or whatever they call it in the JK) so you'd have to hardwire everything like the radio,windows,horn,lights,heater,AC,and convert to manual gauges in the IC panel just to name a few.
Basically there is no way to interface a 30 year old carbed engine to your mondern multiport FI computers without a buttload of $$$.
tjkj2002 is offline
post #3 of 11 Old 09-23-2012, 12:14 PM
scubamc
Really? Would you please provide your source for this information?
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #4 of 11 Old 09-24-2012, 03:22 PM
ltrail
1984 XJ Cherokee
^Check federal emissions regulations. used to be one model year newer or better and from what I understand now there is something about cross breeding. No more Chevrolet in the jeep etc. Not to say that you can't get away with it, but some places don't have emissions and some have inspection and Nazi cops to boot.
Even the theory is a bit off. Going from nice clean fi engine back to carb?
Not that it's not possible but not legal federally speakie. Of course marijuana is federally illegal but doctors prescribing it.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 11 Old 09-24-2012, 05:03 PM
scubamc
The Clean Air Act does not make it illegal to do a swap. It does make it illegal if you are doing the swap to eliminate or bypass the emissions systems.
California has some of the toughest emissions laws in the country. I would be willing to be there is more than one Jeep running around with a LS motor in it.
scubamc is offline
post #6 of 11 Old 09-25-2012, 10:01 AM
ltrail
1984 XJ Cherokee
It clearly state that the replacement engine must be of same model year and emissions certification or newer for light duty vehicles.
Argue with the government not me. Done the swaps, as stated some are Nazi about it and others are not. The swap in question would fall under illegal. Unless I guess you used an 08 or newer GM fuel system and obd . But when you get down to it, you still have a 30 yr old engine on a 5 yr old platform.
ltrail is offline
post #7 of 11 Old 09-25-2012, 12:04 PM
scubamc
I am not arguing with you. Just trying to dispel some internet myths.
This is the paragraph from the Clean Air Act you are referring to.
For light-duty vehicles, installation of a light-duty eng~ne into a different light-duty vehicle by any person would be considered tampering unless the resulting vehicle is identical (with regard to all emission related parts, engine design parameters, and engine calibrations) to a certified configuration of the same or newer model year as the vehicle chassis, or if there is a reasonable basis for knowing that emissions are not adversely affected as described in Memo 1A. The appropriate source for technical information regarding the certified configuration of a vehicle of a particular model year is the vehicle manufacturer.
Here is Memo 1A
scubamc is offline
post #8 of 11 Old 09-25-2012, 12:21 PM
tjkj2002
2002 KJ Liberty
Eitherway it would end up being illegal since a 30 year old carbed engine would not pass '08 model year emissions no matter what how good you are at tuning.The #1 fail point would be no OBDII connector to check readyness status of major emission systems.
If you get past all the non-understandable mumbo jumbo the clean air act also makes it illegal to swap in a non-light duty engine into a light duty vehicle.So in basically swapping a 4BT into a TJ is illegal even if you get past some states that have laws preventing gas to diesel swaps in the 1st place.
tjkj2002 is offline
post #9 of 11 Old 09-25-2012, 12:28 PM
ltrail
1984 XJ Cherokee
Yes scubamc that is what I referred to. The simple beating of a dead horse. It id in all aspects illegal. Adaptation may be possible to hide the actual engine itself by implementing the 08 and newer emissions equipment. Possible? Probably. Plausible nay.
ltrail is offline
post #10 of 11 Old 09-25-2012, 12:44 PM
64tbird
I dont have anything to back me up but i believe you could swap any motor into your jk and get rid of all emissions stuff but that means it would have to be a offroad only vehicle. So you couldnt get plates on it. Putting a 400 carb motor in is a step backwards but you could put a ls or another newer v8 in and make it work but there will be a lot of hoops to jump thru and still a possibility of not getting past emissions.
These are some reasons why i dont want to live in cali ever!
64tbird is offline
post #11 of 11 Old 09-25-2012, 01:03 PM
ltrail
1984 XJ Cherokee
Even here not being so strict on emissions they are cracking down on OHV plates. In turn some of these need emissions and emissions equipment to get the OHV sticker. Spark arresting apparatus or other nonsense and alll that bs just to take my bike for a spin. Notice 2 stroke isn't such a popular bike anymore? Used to seem you could get one in each bike size 50-80-125-250-500 now it's all about the thumpers.
ltrail is offline
