engine swap - JeepForum.com
post #1 of 7 Old 04-29-2012, 06:53 AM Thread Starter
tuffypwn
engine swap
i have a wreckek '93 jeep grand cherokee with a v8 (318) in it runs good and sold same with the tranny and transfer case as well as a '96 grand cherokee with an inline 6 in it bad head gasket though. i was wounding how hard it would be to put the v8 engine, tarnny, and trasfer case from the '93 in to the '96. i have somewhat of an idea of tools i need it is just the electical connections and the pluming of all of everything. please help me miss driving jeeps.
tuffypwn is offline
post #2 of 7 Old 04-30-2012, 05:47 PM
neonhomer
The 93 is OBD-I.. The 96 is OBD-II... you would have to snag the wiring harness and other electrical goodies from a 96+ w/ the 318.....
You probably could use the 93 wiring to run the motor, but the gauges and other electronics are not likely to work.
Also, IIRC, the 96+ v8's use the 46RE transmission... the OBD-I Jeeps use the 46RH..... So you might have to get a different transmission.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #3 of 7 Old 04-30-2012, 11:48 PM Thread Starter
tuffypwn
engine swap
ok thanks but i can make the machanical things work i have a grandpa that is a rot roder so that part wont be a problem but the gauges might be
tuffypwn is offline
post #4 of 7 Old 05-01-2012, 12:05 AM Thread Starter
tuffypwn
engine swap
can i use the gauges ffrom the '93
tuffypwn is offline
post #5 of 7 Old 05-01-2012, 10:09 AM
MoparXJ
1993 XJ Cherokee
You should be able to reuse the temp and oil gauge and volt metter from engine to engine. The tac would need to be adjusted or replaced.
MoparXJ is offline
post #6 of 7 Old 05-01-2012, 02:40 PM
neonhomer
The 93 harness is not going to interface with the 97 harness....
NeonHomer
post #7 of 7 Old 05-02-2012, 02:53 AM Thread Starter
tuffypwn
engine swap
thanks for the info it will come in handy
tuffypwn is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
XJ to YJ Engine Swap, PCM Swap Necessary? md93yj Engines & Drivetrain 1 10-01-2010 10:51 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
Engine Swap ArmaliteJeep Engines & Drivetrain 5 08-14-2007 05:55 AM
