Engine support during motor mount swap - JeepForum.com
post #1 of 4 Old 02-01-2006, 07:07 PM Thread Starter
DustPuppy
DustPuppy's Avatar
Location: Planet Neptune, on patrol near Columbus, Ohio
Hello folks,
I am asking for advice on the best (safest) way to support the weight of the 4.0L HO engine in my '99 XJ in order to replace the motor mount.
According to the FSM, it simply states to "support the engine", which in and of itself is not terribly helpful.
I checked the Hanes manual I have, and it states to use a floor jack and a piece of wood, to spread out the force, and to lift the engine via the oil pan enough to take tension off of the engine to unbolt the mount and replace it.
That sounds like the detail I need, but honestly I do not feel real comfortable supporting part of the engine on the oil pan. Can the oil pan really take that kind of stress without cracking?
My question is, has anyone else supported the engine this way or found another, safer, location to use a floor or bottle jack?
Thanks for any advice you have.
DustPuppy
DustPuppy is offline
post #2 of 4 Old 02-01-2006, 08:22 PM
gumcrew2
1991 XJ Cherokee
The oil pan can definently take it, I've got big *** dents in mine from bigger rocks with more force than the weight of the engine. And I've say down plenty of 4.0L's on the oil pan before. I would say the BEST would be to use a cherry picker and hook it onto the head bolts. But if that's not possible, use a jack and a piece of wood. To keep it balanced you could bolt the piece of wood to the frame and put jackstands under it.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #3 of 4 Old 02-01-2006, 10:02 PM
bobjp
I have also done it with a jack on other engines with no troubles.
bobjp is offline
post #4 of 4 Old 02-03-2006, 09:45 AM
98JEEPTJ
2005 WK
Block and jack under the oil pan works great. Just don't try jacking up the entire vehicle. Loosen your motor mount bolts first and jack then loosen then jack and loosen until your motor is high enough to remove the mounts. The fan shroud is going to get in the way also....so I would remove that...
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
Motor Swap or OEM Motor Mods??? inkpen00 Engines & Drivetrain 7 02-17-2010 07:15 AM
4.0L engine mount/swap 2000_WJ Engines & Drivetrain 2 04-15-2009 11:33 AM
Motor mount tower/motor frame mount location pepto Engines & Drivetrain 3 03-24-2009 02:07 PM
Need help with motor mount plates, 258 to 4.0 swap whittlecj Fabrication Shop 2 12-31-2008 08:44 AM
Easy engine support when removing tranny skid Jeepin' Rock Cl Cheap Tricks & Fixes 1 09-14-2005 10:10 AM
