Engine stalls ??!! - JeepForum.com
post #1 of 10 Old 09-02-2013, 10:35 AM Thread Starter
cody413
Engine stalls ??!!
I have a 92 jeep wrangler yj. I just got a head job done. New fuel filter. New injectors. Cleaned out gas tank. New spark plugs. A lot is brand new. Runs fine till a couple days out of shop. I'll be driving and youl feel it bog a little bit. Then as soon as I stoo and put it in first and try and go. It stalls. Sometimes it will start after like 20 mins. I will have to hold gas pedal all the way down and you'll hear it starting to catch fuel n eventually pixk up and crank. Anyone ever had this happen? I also have a 4 cylinder. Id really have no clue
cody413 is offline
post #2 of 10 Old 09-03-2013, 11:26 AM Thread Starter
cody413
No one??!!
cody413 is offline
post #3 of 10 Old 09-04-2013, 03:15 PM
JeeperCreepers7
Is it a manual?
JeeperCreepers7 is offline
post #4 of 10 Old 09-06-2013, 10:41 AM Thread Starter
cody413
Yes it is. I've brought it to the shop. And of course it didn't happen. And they said its fine. The ride home it misfires/ boggs when putting it in gear while driving. And when I'm at a stop n give it gas just wants to stall. It'll clear up but take a min or so.
cody413 is offline
post #5 of 10 Old 09-06-2013, 09:10 PM
uberxj92
1992 XJ Cherokee
Almost sounds fuel system related
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #6 of 10 Old 09-08-2013, 07:16 PM
copmedic309
1995 XJ Cherokee
Sounds like maybe a fuel pump, either that or check the crankcase position sensor
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
post #7 of 10 Old 09-08-2013, 07:44 PM Thread Starter
cody413
Its something fuel related for sure. I'm gonna take it for a drive tomarrow and put a tester onvthe duel rail when it stalls. And see what I get. I was thinking some kind of sensor. Which is a lot cheaper than a fuel pump.
cody413 is offline
post #8 of 10 Old 09-10-2013, 02:01 PM Thread Starter
cody413
I checked the fuel pressure at the rail when it started bogging ouy. It was good. I also had my muffler blow open from the past. I replaced it. Someone told me it could be throwing off the back pressure which could mess with the oxygen sensor? I'm gonna get it home and start testing everything n hope to come across something. If anyone has ANY ideas please add. Thanks
cody413 is offline
post #9 of 10 Old 09-10-2013, 07:59 PM
uberxj92
1992 XJ Cherokee
Check the cat see if it glowing. Sounds like it could be stopped up.
uberxj92 is offline
post #10 of 10 Old 09-11-2013, 03:38 PM Thread Starter
cody413
I had new injectors in it. Which sprayed morevit had 3 lil hole. So just guessing since it smelt strong of fuel when it bogged down. I put in the stock ones which were still good. Bogged but not as bad. N didn't smell to much of gas. Then I swithched out ignition coils. Old one was rusted. N also the TPS and drove around for a hour and no signs of anything. ight have found the problem
cody413 is offline
fuel problem , stalls , wont start
