Engine sporadically wants to die - JeepForum.com
post #1 of 2 Old 09-16-2017, 02:20 PM Thread Starter
JOMA352
I have a 1996 jeep Cherokee with the straight six and it randomly wants to die for just a split second. Its like the whole engine dies for a split second and the kicks right back in like nothing happened. Happens at idle, acceleration, and cruising. I just put in a brand new distributor, ignition coil, MSD wires, crank position sensor, and throttle position sensor. No CEL so I dont have a code to even go with. Any ideas what it is? Everything ignition wise is brand new (maybe 100 miles) so I'm thinking fuel? Thanks for the input
Joma352
1996 Jeep Cherokee
3 inch Rustys Lift
31" Goodyear Wrangler
(Work in Progress)
JOMA352 is offline
post #2 of 2 Old 09-16-2017, 10:15 PM
mukluk
Quite possible it's a fuel issue. I'd check the wiring for the fuel pump to make sure it's not damaged, especially in any areas where it's in close proximity to suspension parts. You could also try installing a fuel pressure gauge to verify the pump output is right about 49psi and holds steady at all engine speeds.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
