Engine Serial Numbers and Build date don't make sense. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Engine Serial Numbers and Build date don't make sense.
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 07-21-2013, 08:47 PM   #1
fletcha221
Ive spent the entire evening searching the internet trying to figure out what year the motor is in my keep. The motor was replaced by the prior owner.
The case is "EF3235444", which tells me it's a 81-85.
The build date code reads "908CL30" which does not jive with anything i've seen. it's tough to see the first 2 digits in the picture.
Anyone else have any ideas? I see gthe engine code "C" but not "CL".
Ideas?
fletcha221 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 07:17 AM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
August 30, 1989. CL is probably 258 whereas MX is 4.0
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 07:50 AM   #3
fletcha221
Hear me out on this one.
I think it's a 1979, not 89. The serial number on the case indicates that these motors were used from 81-85. My best guess is that this motor left the plant in August of 79, and was eventually placed in a model year 1981 Jeep...in 1980? Clear as mud.
From everything I've read the "C" does indicate that it is a 258, when referring to that year range. However, I have not read ANYTHING that mentions a CL.
Unread 07-22-2013, 08:20 AM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check this out. You may have a 232?
http://forums.off-road.com/jeep-shor...d-history.html
Unread 07-22-2013, 11:02 AM   #5
fletcha221
Wow, now my head is spinning. If it IS a 232, it was built in August 31, 1976.
Is there any chance they stamped a 232 with the case # EF3235444?
Where is the head stamped? I couldnt see any numbers.....I assumed it was covered by the intake and exhaust manifold.
Unread 07-22-2013, 12:20 PM   #6
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This help?
http://engineguy.com/1983-81-jeep-4-...a03-vin-c.html
Unread 07-22-2013, 01:13 PM   #7
fletcha221
So that's what the serial # reads on the block, which means 81-85. However, there is a "CL" not a "C" in the build date code. That is what is throwing me off.
Unread 07-22-2013, 01:15 PM   #8
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What does the L mean?
Unread 07-22-2013, 01:43 PM   #9
fletcha221
My point exactly...........I have no idea. From what I read, the C means it's the 258, but the L? No idea.
Maybe "LOW COMPRESSION?"?
No idea.
