Engine quit - JeepForum.com
post #1 of 11 Old 05-31-2001, 12:25 AM Thread Starter
Bandit
Engine quit
I just pulled into my neighborhood and my "97" YJ just quit. Its got gas and the battery is up. It'll start and run for a couple of seconds but then quits again. Any insight on whats wrong????
2002 TJ "X"
31" Goodyear MTRs
2" Rusty's Coil Lift
JKS Quicker Disconnects
iPod Mini - FM Modulator
"Trying to keep the rubber side down!"
Bandit is offline
post #2 of 11 Old 05-31-2001, 07:53 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Does it act like an electrical or a fuel problem?
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 11 Old 06-29-2001, 03:11 PM
90YJ
It sounds like a clogged fuel filter. A clogged filter would manifest itself with the symptoms you describe... just a guess, and an easy place to start.
- 90' YJ 2.5L 5 Spd.
- 3.5" BDS lift with Rancho 9000's
- Borla header
- Steelhorse buckets
- 31" BFG AT's
- Lockrite rear locker
- Hi-Lift Jack
- Nerf bars
90YJ is offline
post #4 of 11 Old 06-30-2001, 12:46 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
If I remember right you have an electric fuel pump .. pull the gas line off, have someone try to start it (make the gas flow) .. there is an amount that needs to be measured in an amount of time to be right ..
I think its like a teaspoon / 10 seconds or something .. can someone confirm for the 4 cylinder?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 11 Old 07-02-2001, 02:50 AM
bigjeep39
bigjeep39's Avatar
Actually, i am having the same probs, but with a 89 yj 6cyl,(read article in yj forum), i wouldn't say 4 teaspoons, it a pint for every 30 seconds, that might help, but i am fixing mine, got a mechanical fuel pump and fuel filter, still not working, i might air out all fuel lines and flush gast tan to make sure nothing clogs the lines, hope that helps.
1998 TJ
Slow steady project.
bigjeep39 is offline
post #6 of 11 Old 07-20-2001, 02:43 AM
Adjone
I have had this problem and have had to replace the coil 3 times over the last 3 years. 94 Grand Cherokee 4.0.
I am trying to find out why they are going bad. Does anyone have a clue?
This is not normal.
Adjone
Adjone is offline
post #7 of 11 Old 08-04-2001, 08:54 AM
HighCountry
I am playing with a similar problem on my '95 Cherokee 4.0. It runs fine until the engine reaches full operating temperature and thens dies STONE dead. Won't do a thing until it cools off to about 100 degrees. My problem is electronic, there is no spark from the ignition when this occurs.
I posted this as a question on another section of this board.
Thanks, Bruce
HighCountry is offline
post #8 of 11 Old 08-04-2001, 11:17 AM
dburton
Sounds to me like everyone having these problems all need to check your ignition module. These are the weakest link on your ignition system. It will cause no spark,burned out coils,and heatup and die problems or sometimes it will start and run and then shut off just like you turned off the key any of these problems sound familiar? generally mounted on left fender below the windshield washer jug. Any good auto parts store can check them. good luck hope this helps. Darin
89 YJ 4.2L auto 3in lift w33 Goodyear MTR's Corpus Christi Tx.
dburton is offline
post #9 of 11 Old 08-06-2001, 12:36 AM
HighCountry
I have an update to my problem. It appears that a corroded wiring harness connector for the "Crankshaft Posistion Sensor" may be to blame. I read about that posibility on another trouble shooting site. Sure enough, when I unplugged my "CPS" harness the pins were corroded.
I have cleaned up the pins and the female receptacles, then applied a dose of "Corrosion Block". I will keep you posted if this is a fix!!!
Bruce
post #10 of 11 Old 08-13-2001, 08:59 PM
iamthemellowman
hmmm,
this cutout when warm sounds like the problem a co-worker is having. His is a 4.2L wrangler. basically it'll start losing power as it warms up. (replaced the obvious things, pump, filter) described as a condition where anymore throttle than 1/2 and the engine cuts out (yes choke plate is all the way open)
So, does this motor have either or both of the ignition module or CPS?
thanks,
Tim
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #11 of 11 Old 08-15-2001, 12:31 AM
HighCountry
Ooops, sorry! Regretfully, our 4.0s are having an electronic control system problem while your buddy is having goodness knows what! Our system is an instant "die-restart" problem just as though you turned off the ignition.
I would imagine that his 4.2 is carbureted? If so, I would make sure that the EGR valve is working correctly. If you fellows are unsure how to check that, repost the problem here and someone will help you out! Important thing is to remember to KISS (Keep It Simple Stupid) and not overcomplicate the problem.
Take care, Bruce
TJ Wipers Quit on Me. Help hammer99tjdd Audio, CB & Ham Radios, GPS, & Electrical 5 04-30-2008 01:29 PM
Sub quit working jeep-n00b Audio, CB & Ham Radios, GPS, & Electrical 5 07-03-2007 03:11 PM
AC quit jeep nomad Engines & Drivetrain 2 09-12-2006 10:26 AM
Speakers all quit Steveqvs Audio, CB & Ham Radios, GPS, & Electrical 2 03-08-2005 01:01 PM
All gauges just quit on my tj.... wtf? KGJeepTJ Audio, CB & Ham Radios, GPS, & Electrical 2 05-30-2004 05:15 PM
