engine problems! help! - JeepForum.com
post #1 of 10 Old 11-05-2008, 01:36 PM Thread Starter
Dutchie123
Im having some problems with my engine that i can't figure out. My engine will be idling fine then all of sudden totally bog out and try to stall. Soo, i changed the fuel filter, dist cap is new, plug and wires are new, air filter is new, brought it in and got the timing worked on and got a hole blown through the cat convertor. I also got the fuel pressure taken and that was also good. Any ideas?
Dutchie123 is offline
post #2 of 10 Old 11-05-2008, 09:09 PM
wawheeler
do you have the 4.0 or the 2.5?
89' YJ , 01' TJ
Justify's
Every
Ecological
Problem
wawheeler is offline
post #3 of 10 Old 11-06-2008, 02:39 PM Thread Starter
Dutchie123
i have the 2.5
post #4 of 10 Old 11-06-2008, 10:20 PM
wawheeler
well in a 91' i would imagine that it is the same as my 89' which is an AMC 150. they are finicy*but mine seems to keep on kicking. it might poor gas qaulity or some gunk in your gas tank. i would try a variety of fuel additives, or maybe some injector cleaners (the gas additive kind).
89' YJ , 01' TJ
Justify's
Every
Ecological
Problem
post #5 of 10 Old 11-07-2008, 08:26 PM Thread Starter
Dutchie123
alright ill give that a try and keep u posted
post #6 of 10 Old 11-07-2008, 08:29 PM
Chillpill109
Is it a bad clutch? I notice when your clutch starts to go out it shutters up a bit when in neutral, or is it an auto?
Chillpill109 is offline
post #7 of 10 Old 11-07-2008, 08:39 PM
Kraemer
pardon my ignorance, but I think in 91 the 2.5's were fuel injected?
if it is indeed FI, check the iac solenoid operation. (if your unsure, buy a repair manual from local parts store, you should own one anyway)
does it have A/C? Is your defrost on ?
what is the actual rpm difference?
has it done this as long as you've known, or is it a new problem?
00' XJ
81' Yota
a garage full of parts...
Kraemer is offline
post #8 of 10 Old 11-09-2008, 12:19 PM Thread Starter
Dutchie123
its a new clutch so it cant be that, i tried the additive, so far no dice on that. But i will check my haynes manual for the iac selenoid. This still boggles my mind what it is
post #9 of 10 Old 11-13-2008, 05:37 AM
sootyjeep
2006 KJ Liberty
there is a pickup in the distributor that's a common repair
The only replacement for displacement is Positive Manifold Pressure.
sootyjeep is offline
post #10 of 10 Old 11-13-2008, 08:15 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
yes, the 91 is a multi point fuel injection system.
retrieve the codes if any, and go from there.
there are also a lot of tests to be doe with various sensors etc. read the shop manual (haynes, chilton, etc) and go from there
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Engine Problems brunhean Engines & Drivetrain 7 02-17-2010 08:00 AM
More problems w/ engine bay Rokjeep Engines & Drivetrain 1 02-11-2010 06:10 AM
engine problems tippmann243 Engines & Drivetrain 11 04-02-2007 06:04 PM
Engine problems.. BigYellaJeep Engines & Drivetrain 9 02-13-2006 05:23 PM
90 Yj Wrangler Engine Problems robb92 Engines & Drivetrain 8 07-19-2002 09:19 AM
