Engine Problems HELP! - JeepForum.com
post #1 of 7 Old 11-21-2011, 01:02 AM Thread Starter
aheffner
1996 FSJ Cherokee
So, I just bought a brand new battery for my 1996 Jeep Cherokee Sport 6 cyl. because the old one was crap. But the new one died today. I had my friend jump it for me and it will start with a few presses of the gas pedal but as soon as I let off the gas the engine stops. It won't stay running. I have no clue whats going on. ;/ Its killing my pockets.
aheffner is offline
post #2 of 7 Old 11-21-2011, 01:51 AM
Drix
Put a multimeter on it while it's running you should get a bit over 14vdc if the alternator is running. If not it's a good chance your alternator is not working.
If you have no meter and can get it to a parts store in the morning they should be as to hook you up and test it and the battery.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #3 of 7 Old 11-21-2011, 06:54 PM
rjbruzan
The computer Jeeps REQUIRE a fully charged battery to make all systems work properly. So either charge it or keep the revs up to let the alternator charge it up. Next fix the drain or youll be buying another battery because they can only be killed dead so many times before they are junk.
rjbruzan is offline
post #4 of 7 Old 11-25-2011, 09:16 PM Thread Starter
aheffner
1996 FSJ Cherokee
I cant figure out whats killing my battery. The only thing I could think is the little light around the keyhole. But could that really drain a whole battery?
aheffner is offline
post #5 of 7 Old 11-26-2011, 05:06 PM
rjbruzan
Yes if it stays on after the Jeep is shut off.
rjbruzan is offline
post #6 of 7 Old 11-26-2011, 05:27 PM
herbiehind
disconnect the neg. cable and put meter in series with neg . on amps . if reading more than milliamps you've got a draw . if so pull fuses till it's gone . then look to that circuit for the culprit .
herbiehind is offline
post #7 of 7 Old 11-01-2012, 08:10 PM Thread Starter
aheffner
1996 FSJ Cherokee
I found out I just had to keep pumping my gas until my computer restarted, and then we disconnected the the light around my ignition and it stopped dying. So thank you lol. But now we have more problems after having my baby run great for a while. Uhg.
aheffner is offline
battery , engine , problems , starter
engine problems 25greenwrangler Engines & Drivetrain 0 08-02-2011 02:05 AM
98 tj 4.0L engine problems help!! j3rs3yd3vil Engines & Drivetrain 2 07-03-2010 12:21 PM
engine problems! help! Dutchie123 Engines & Drivetrain 9 11-13-2008 08:15 PM
engine problems tippmann243 Engines & Drivetrain 11 04-02-2007 06:04 PM
Engine problems.. BigYellaJeep Engines & Drivetrain 9 02-13-2006 05:23 PM
