engine problems - JeepForum.com
post #1 of 12 Old 02-03-2007, 05:53 PM Thread Starter
tippmann243
engine problems
welp im working on my jeep its a 1990 carb'ed 4.2 6 cylinder
i had a problem with it running like **** and it turned out i had about 30 vac leaks and a bad choke (made it hard to start)
anyhoo i deleted about a mile of vac hose and vac modulators that control emission crap.
i adjusted the carb mixture and reset the idle
adjusted timing by what the engine calls for and it runs like complete **** and wants to stall out and bucks and backfires under load. it would NOT idle with the egr hooked up. so it was left unplugged
then i reset the timing using a vac guage and it runs like a top, starts SUPER easy idles smooth, but it pings its *** off under a moderate load. i tired topping it off with premium fuel (92 octane) i put in 6 gallons (gives me an octane rating of ~88.5) and it still pings its *** off. this time it would idle with the egr working but it idle rough and would randomly stall out.
any input on what i can do to get it running good and get it to quit pinging.
im gonna try and figure out whats up with the egr valve tomorrow
thanks
-mark
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #2 of 12 Old 02-03-2007, 08:47 PM
Rivi
turn the timing back a little at a time until the pinging stops.
Rivi is offline
post #3 of 12 Old 02-03-2007, 10:24 PM Thread Starter
tippmann243
if we set the timing anywhere besides where it pull the most vac at idle it becomes hard to start, boggy and backfires out the exhaust/carb.
blazer video,
post #4 of 12 Old 02-03-2007, 11:05 PM
Gregersonke
Run a treatment of Seafoam through it... Should clean out the carbon deposits that were most likely building up over time in your engine and are the likely culprits for the pinging now.
Gregersonke is offline
post #5 of 12 Old 02-04-2007, 09:05 AM Thread Starter
tippmann243
did that about 500 miles ago, all it did was give a nice smoke show
blazer video,
post #6 of 12 Old 02-04-2007, 09:11 AM Thread Starter
tippmann243
well i guess i should give soem more details.
anything you cna think of i have done to this thing in order to get it running decent. well alomst everything besides replacing the carb for a webber unit.
so far i have
tuned it up and adjusted the carb idle mixture, it also has a jacobs? high energy ignition unit
replaced fuel filter
carb cleaned the piss out of the carb
cleaned the air filter (k/N)
the motor has a good ammound of blow by so i removed the one hose that blows back into the intake and vented it to the atmosphere
replaced the choke ( it was inoperable)
seafomed the motor (half can in the crank case half in the gas, whole can through the brake booster vac line)
i deleted a metric butload of that vac line BS that comes on these motors. so far that has helped the most in ease of starting and ability stay running
blazer video,
post #7 of 12 Old 02-05-2007, 11:23 AM
KrazyGimp
1982 CJ5
What carb do you have in there? Is it by chance a Carter with a computer? If so you need to look into doing the nutter bypass. The computer in there controls the timing so no ammount of replacing parts or turning the distributor is going to help your pinging issues, because the computer is actually still trying to control it. Also, did you just start ripping out vacuum lines and what not? All of that stuff is interconnected. To remove all the emissions stuff you really need to just upgrade carbs and go with an HEI ingnition.
Here is a link that explains what all the junk under the hood is. I know its for a CJ but they are the same motor and share alot of the same emissions components.
http://home.sprynet.com/~dale02/
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #8 of 12 Old 02-05-2007, 01:26 PM
blueknight44
try removing the EGR valve, spray carb /injector cleaner on the piston, clean the carbon off.
Work the valve by hand until it moves freely.
I had bad carbon buildup that made the EGR valve stick and it wouldn't idle but it would run at a high speed then die.
Good luck.
blueknight44 is offline
post #9 of 12 Old 02-13-2007, 08:16 PM Thread Starter
tippmann243
thanks ill look into this
Good luck.
did that the same time i seafoamed the motor, the diaphram moves flawlessly with now sticky spots
blazer video,
post #10 of 12 Old 04-01-2007, 03:45 PM Thread Starter
tippmann243
welp i finally got around to working on the jeep again since im parking my blazer for some more mods.
did the nutter bypass and it runs like a champ, no more pinging and starts easier, it still needs a new carb but at least it runs good now
thanks for all the help guys
blazer video,
post #11 of 12 Old 04-01-2007, 06:33 PM
HiMiles91XJ
Off topic, but how much compression does your 4.3 have, and how much boost are you pushing? Looks like you could hit 11's with that trap.
'07 Yamaha Virago
'80 Yamaha XS1100G
'86 Ford Turbocoupe: T5, T3, 18 psi, daily driver: FOR SALE-Contact me if interested
HiMiles91XJ is offline
post #12 of 12 Old 04-02-2007, 06:04 PM Thread Starter
tippmann243
8.5:1 with 8 psi
blazer video,
Engine Problems brunhean Engines & Drivetrain 7 02-17-2010 08:00 AM
More problems w/ engine bay Rokjeep Engines & Drivetrain 1 02-11-2010 06:10 AM
engine problems! help! Dutchie123 Engines & Drivetrain 9 11-13-2008 08:15 PM
Engine problems.. BigYellaJeep Engines & Drivetrain 9 02-13-2006 05:23 PM
Hot engine electrical problems CJ10a Engines & Drivetrain 4 04-07-2002 05:49 PM
