Engine overheating - JeepForum.com
post #1 of 10 Old 07-10-2013, 07:40 PM Thread Starter
raven8706
1977 CJ5
Engine overheating
Hey everyone, I recently upgraded my engine from the inline 6 to the amc 304. I drove it home from the shop and as soon as I pull in my radiator starts dumping water out of the overflow tube. I am getting a reservoir and a fan shroud . Is there any thing else you guys can think of that I should try?
raven8706 is offline
post #2 of 10 Old 07-10-2013, 08:23 PM
DaemonForce
No that all sounds good to me. I've never played around with the V blocks but it sounds like you've got the coolant levels broken in where they need to be. I noticed my 258 dumping coolant into the overflow tank after I changed the water pump. This doesn't sound scary to me. What is the temp gauge doing?
DaemonForce is offline
post #3 of 10 Old 07-10-2013, 11:47 PM Thread Starter
raven8706
1977 CJ5
For some reason there is no overflow tank. I drove it for 30 mins after 15 mins I was at the edge of the green line toward the hot so I stopped the fluids in my radiator was frothy. I finally made it to where I was going but couldn't go above 40 mph.
post #4 of 10 Old 07-11-2013, 12:44 AM
DaemonForce
It was having physical trouble going above 40MPH? Okay THAT is a problem. First things that come to mind: Check oil level, check transmission fluid, check coolant levels and thermostat, check vacuum pressure. Whenever an I6 starts to dog, that sends me into a panic. The V8 is too strong to be sharing these problems and I doubt it should be running hot, ever. What kind of radiator are you using?
post #5 of 10 Old 07-11-2013, 12:55 AM Thread Starter
raven8706
1977 CJ5
It is the stock one for right now. I am getting a new one next month if everything works well. As far as going over 40 it will its just that it starts to get to hot
post #6 of 10 Old 07-11-2013, 04:21 AM
DaemonForce
Do you have ridiculously low gears that make this a bad idea for the highway?
post #7 of 10 Old 07-11-2013, 05:42 AM Thread Starter
raven8706
1977 CJ5
As far as gears it's all stock ratios. I did just notice that they did not reconnect my exhaust so that might cause my over heating problem
post #8 of 10 Old 07-11-2013, 07:07 AM
DaemonForce
You should address any and all manifold leaks before getting started on anything else. At least this part is easy.
post #9 of 10 Old 07-11-2013, 07:45 AM Thread Starter
raven8706
1977 CJ5
Ya I'm going to get some pipes to put on there but will this cut down on the over heating
post #10 of 10 Old 07-11-2013, 09:05 AM
DaemonForce
My primary concern isn't so much the exhaust fumes but the pressure of those fumes. I've encountered a lot of stupid with air/fuel systems where a leaking exhaust was causing operation problems. If you have leaks in the gaskets, that would probably show you the sort of thing I went through but the issue here is heat and reproducing that problem. Are any of the hoses kinked? What is the condition of this 304? Has it been sitting for years and you just dropped it in? Did you do a full assembly? Either way it sounds like the thermostat might need to be replaced. I know the 258 is supposed to run around 180 but I have no idea what belongs in the 304. Probably runs at 195?
