engine cutoff - JeepForum.com
post #1 of 7 Old 11-17-2012, 02:57 PM Thread Starter
mslinger
engine cutoff
Still have cutoff trouble with 83 cj5 with 4.2 have replaced carb gas tank fuel pumps filters and ignition module still will cutoff like you turn switch of thought about unhooking return line from fuel filter do u need that line any help would b appreciated. Thanks
mslinger is offline
post #2 of 7 Old 11-18-2012, 07:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check the connections/plug on your ignition switch first. They melt/burn sometimes.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 7 Old 11-18-2012, 04:14 PM Thread Starter
mslinger
Thanks I'll try that next
mslinger is offline
post #4 of 7 Old 11-18-2012, 04:54 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's a pic.
post #5 of 7 Old 11-18-2012, 04:56 PM Thread Starter
mslinger
Where is it located?
mslinger is offline
post #6 of 7 Old 11-18-2012, 05:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Under the dash on top of the steering column.
post #7 of 7 Old 11-19-2012, 06:54 AM Thread Starter
mslinger
Thank you
mslinger is offline
