Engine codes - JeepForum.com
post #1 of 6 Old 10-24-2013, 08:48 AM Thread Starter
abntrptr
Engine codes
I have a 2010 JK with 46k miles, the check engine light just came on and the code says EVAP Control System Leak Detected Very Small Leak (P0456). Anyone else have this issue and what was your fix? It says it could be anything from a fuel cap issue to EVAP canister to EVAP hose to leaking fuel tank.
abntrptr is offline
post #2 of 6 Old 10-24-2013, 04:23 PM Thread Starter
abntrptr
I have checked the gas cap and it is on properly
abntrptr is offline
post #3 of 6 Old 10-24-2013, 05:52 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The OEM gas cap has the little plastic keeper attached to the middle of it. Inside the cap there is a pressure relief valve mechanism. Some of the bits are metal and they corrode. If you have some silicone spray, shoot a bunch of silicone into the cap. If that makes the CEL say off for a while after you clear the code and shut the CEL off then you know that the gas cap is the problem.
Get a new generic cap for $8.00 or so at your local parts store. NOT another OEM unit that has that keeper.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 6 Old 10-24-2013, 07:19 PM Thread Starter
abntrptr
Laybackman, definitely the problem, I sprayed some compressed air up in there and that seems to have done the trick. Thanks
abntrptr is offline
post #5 of 6 Old 10-24-2013, 07:27 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
post #6 of 6 Old 10-24-2013, 08:49 PM
GilaMtnJeep
GilaMtnJeep's Avatar
If you haven't bought a new one yet, don't get a cheap one. Buy a quality brand such as Stant.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
