Engine codes - JeepForum.com
post #1 of 7 Old 03-02-2002, 11:38 AM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Engine codes
Can anyone tell me what the 2 engine codes 12 and 45 mean? The haynes manual does not list these. The "check engine" light stays on. Sometimes I can clean the two O2 sensors and disconnect the battery and this will clear the codes for a while but they still come back.
1997 Black XJ Sport 4x4, 1" Shackle/coil spacer lift, Ram Brush guard w/ 6in spot lights, Smittybilt Nerf bars, Class III Hidden Hitch, Elliptical Driving Lamps, Prime Wheels#234 15x8.5, 30x9.50r15, BFG AT's, JVC CD player, Alpine V12 Amp, 1-12in RockfordFosgate Subs, 5-1/4 Rockford Fosgate component speakers in doors & sound bar, Euro-spoiler, Pacesetter Cat-Back, Optima Red Top battery, HID Headlamp Conversion, Gabriel Hijacker Air Shocks on rear axle
Gacherokee is offline
post #2 of 7 Old 03-03-2002, 09:18 AM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
OK I found out that 12 is the number that preceeds the code output. On 1984-1986 code 45 means that it has a rich exhaust, so is this the same on 1991 and later models? I checked the exhaust and replaced one of the oxygen sensors but it still gave me the check engine light. do I need to change out the down stream sensor @ the cat?
post #3 of 7 Old 03-05-2002, 02:23 PM
NC74CJ
NC74CJ's Avatar
Im not sure of what the code is for you model, but if you isolated the problem and replaced it the computer will still display the check engine light for a while. It automatically resets after a number of restarts, but you just need to pull both battery cables off to reset it. Good Luck
Bill
A stroke bolder, a pinch better.
NC74CJ is offline
post #4 of 7 Old 03-06-2002, 07:54 PM
MdJEEP420
your screwed...Its the stupid OBD2 computer. I got a 97 TJ..same thing..Flukey Check Engine light..im convinced my truck has AIDS and is going to die. I just moved from Florida..so I think that COLD air in the morning may have something to do with it. Just get used to it..and if it pisses ya off to bad..There is always an ICE PICK!...
MdJEEP420 is offline
post #5 of 7 Old 03-06-2002, 08:39 PM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Yeah we had a high in the mid 60's today and my wife said she noticed that the light went off when stopped using the heater!?! I don't get it. I wonder if there may be a recall on the computer?
post #6 of 7 Old 03-07-2002, 04:56 AM
bonehead99
bonehead99's Avatar
goto Car Point you can sign up to have them email you if there are any recalls on your Jeep.
AllPar has a list of all the different codes.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #7 of 7 Old 03-07-2002, 08:56 AM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Thanks, Bonehead99
the allpar site helped out, but code 45 had to do with a turbo sensor and I do not beleive that the XJ even has a Turbo. But thanks for the sites anyhow, may come in handy in the future!!
Engine error codes, Is this possible? Gr8fulDeadHead Audio, CB & Ham Radios, GPS, & Electrical 4 07-06-2008 03:57 PM
Engine light on, but no codes. 0utback Engines & Drivetrain 4 01-26-2008 03:00 PM
Engine Diagnostic Codes for 2004 TJ Willys2004 Engines & Drivetrain 2 09-02-2006 12:04 AM
CB 10 Codes. LoneJeeper Audio, CB & Ham Radios, GPS, & Electrical 3 04-29-2005 03:47 PM
Engine codes Trainer Engines & Drivetrain 2 09-18-2003 01:46 PM
