engine cleaner / valvetrain cleaner? - JeepForum.com
post #1 of 9 Old 02-12-2007, 07:15 PM Thread Starter
BNovak
BNovak's Avatar
Alright - other than Kerosene anyone got suggestions for getting the crap out of the intake and exhaust ports?
I went at it with a wirewheel on my dremel but that didn't work (the wheel actually disintegrated) going to go back to ACE tomorrow and see if I can get a long stiff wirewheel and see if that works.
in the meantime, any ideas are well taken!
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #2 of 9 Old 02-12-2007, 07:27 PM
tscuda
carb or brake cleaner
tscuda is offline
post #3 of 9 Old 02-12-2007, 09:44 PM Thread Starter
BNovak
BNovak's Avatar
Doesn't work - I need something with some sticking power. I'm getting ready to try some foam stuff I saw at autozone.
BNovak is offline
post #4 of 9 Old 02-12-2007, 09:54 PM
ademster
1982 CJ7
Get seafoam or go to a GM dealer and buy some TOP ENGINE CLEANER
in middle of surgery,
getting 14 bolt rear xj-springs,
frt Dana 60 YJ-springs
39.5X13.5R17 Bias Iroks,
black steelies will have K.O.R.E diy beadlocks
and mis other stuff will be done
ademster is offline
post #5 of 9 Old 02-13-2007, 05:52 AM
75SV1
Is this engine apart? If so I'd look at engine cleaner. The foaming type works OK. I'd take it to a car wask. Spray on the stuff and let soak for awhile. Castrol Purple Power works good to, but I wouldn't let it stand on aluminum very long. I buy some stuff at True Value call Contractor's Cleaner. It works good to. There is something called Greased Lightning with orange power. I have tried it to, seems to work OK.
Are you porting your head? Then I'd see what an engine shop would charge to clean and inspect it. I think I had mine done for $50. I've heard as high as $100.
Tom
75SV1 is offline
post #6 of 9 Old 02-13-2007, 09:16 AM Thread Starter
BNovak
BNovak's Avatar
Thanks Guys
Yeah the engine is apart so Seafoam / Top engine cleaner (same thing, go figure) won't work since there's no way to get compression or heat.
I never even thought about the car wash!
BNovak is offline
post #7 of 9 Old 02-13-2007, 09:45 AM
75SV1
A thought might be oven cleaner and stick it in the oven. If your not married this might work. Otherwise, I'd stick with the car wash or pay a shop to clean it. You could lspray it with simple green or some orange cleaner and let sit over night. I did this recently with a vacum pump from a diesel motor. It cleaned up pretty good in the solvent tank at work. Also, might get a tooth brush or a brass or stainless steel parts brush from the atuo or hardware store. They bust up the junk a bit, between washings.
Tom
75SV1 is offline
post #8 of 9 Old 02-13-2007, 03:04 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
wd-40 let it sit over night
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #9 of 9 Old 02-14-2007, 05:44 PM Thread Starter
BNovak
BNovak's Avatar
and the winner is a stiff wire brush on my air grinder.
One more port to go and I'll take some pictures! (probably tomorrow though...have to make the wifey dinner )
=-BN
BNovak is offline
Steam Cleaner for engine bay? CLNinja General Jeep & Off-Road Equipment 0 11-03-2008 10:46 AM
Rec on the Best Engine Cleaner WillysJeeper Engines & Drivetrain 4 01-06-2007 07:17 PM
Engine Cleaner Willys2004 Engines & Drivetrain 4 08-20-2006 02:51 PM
Engine Cleaner? EBlax04 Engines & Drivetrain 2 10-28-2004 05:21 PM
What's a good cleaner for the engine bay? ChiTown'01XJ Engines & Drivetrain 10 08-03-2004 04:08 PM
