Engine block soft plugs. - JeepForum.com
post #1 of 7 Old 01-25-2005, 12:11 PM Thread Starter
junior72
I own an 84' Jeep JC7 w/ an in-line 6 cylinder that has about 500 miles on it after a rebuild. Everything under the hood is also brand new. The Jeep overheated after only a ten minute drive and had shown no previous signs of running hotter. When I checked it, I saw that it was missing one of the soft plugs on the driver's side of the engine bolck and spilling coolant through it. What are these for? What causes these to pop out? Is this repairable or does the engine block need to be replaced? HELP???
junior72 is offline
post #2 of 7 Old 01-25-2005, 10:45 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
It's where they drain the sand after casting. It probably wasn't installed properly. Unless you ruined something overheating it, you should be able to simply replace it.
jeepdaddy2000 is offline
post #3 of 7 Old 01-26-2005, 05:47 AM
BamaJeeper
BamaJeeper's Avatar
Return it to the rebuilder and have them fix it. That way they will know about it when they rebuild the next guys motor and hopefully make you happy by making things right.
Out of the darkness comes light.
BamaJeeper is offline
post #4 of 7 Old 01-26-2005, 05:48 AM
BamaJeeper
BamaJeeper's Avatar
Oh yeah. If the coolant system happens to build enough pressure the plugs can pop out.
post #5 of 7 Old 01-26-2005, 03:15 PM
AudioGuru
AudioGuru's Avatar
They're dual purpose, they allow access to the interior passages of the block during the casting process and they also protect the block from cracking if the coolant were to freeze. Sometimes they're referred to as "frost plugs" for this reason. In rarer cases they'll pop out during overheating, but usually the hoses will let go first.
Don't lie. God said so.
AudioGuru is offline
post #6 of 7 Old 01-26-2005, 08:17 PM
mrgeoff
"frost plugs"
how about freeze plugs.
I got you covered
mrgeoff is offline
post #7 of 7 Old 01-30-2005, 09:24 PM
Dembones
Dembones's Avatar
Forget the plug, throw a block heater in that bad boy
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Dembones is offline
did i destroy my engine block? strivingfirst Engines & Drivetrain 7 12-10-2008 11:41 PM
where to pick up a engine block from mad_skillz Engines & Drivetrain 2 10-23-2008 12:59 PM
Engine Block Drainplug 4.0 ComancheScreen Engines & Drivetrain 0 09-27-2007 03:54 AM
engine block prep nichols077 General Jeep & Off-Road Equipment 0 05-21-2007 04:35 PM
4.0 engine block digibus Engines & Drivetrain 0 06-03-2005 07:11 AM
