Engine Bay caught fire - 97 TJ - JeepForum.com
post #1 of 3 Old 02-11-2011, 12:46 PM Thread Starter
Maximus1215
Hi!! Sorry if this is in the wrong section. Lastnight, I was in my garage, and I went to start my jeep, and it made a weird clicking noise, then when it turned on, the RPM's shot up like the throttle was stuck. I immediately turned it off, and opened the hood, and inspected the throttle cable and TB. I tried to start it again - this time it just made the clicking noise, then I heard a small sound, similar to what it sounds like when a gas stove burner turns on. I get out (hood was up blocking my view) to find my engine compartment completely up in flames!!! I ran and got a fire ext. and put it out as fast as I could. Afterwards I noticed that one of my fuel injectors was burned and the cable was disconnected from it - not sure if it blew off, was loose, etc. Upon a quick inspection, none of the wiring seems to have been damaged. I am going to investigate it more thoroughly tonight and tomorrow - my question (finally!!) is - is there anything specific I should check first that will not allow my jeep to function properly. I'm not a mechanic by trade, but I do my own work, so I feel comfortable in checking things out, I just have never dealt with an engine fire before and wanted to just check with the forum to see if there is anything/anywhere I should direct my attention to first. - Sorry for the long read.
Maximus1215 is offline
post #2 of 3 Old 02-11-2011, 12:53 PM
MONSooNmonkey
Check battery if dead you likely have a grounded out wire that also created the ignition source. Could have been arcing and finally took flame, that along with a failed injector or damaged injector could have leaked pressurized fuel and caused it.
Trace down ignition wires, starter wires and injector wires.
Sadface :(
MONSooNmonkey is offline
post #3 of 3 Old 02-11-2011, 12:57 PM Thread Starter
Maximus1215
Thank you for the quick response and good ideas!!!
I can't get the engine to fire! EspiritoSanto Engines & Drivetrain 0 09-26-2010 10:10 PM
Small fire causes engine to not start. 91 Grand Wag egoods Engines & Drivetrain 1 04-09-2010 05:12 PM
HELP fuse box just caught on fire (XJ) beaucaldwell Audio, CB & Ham Radios, GPS, & Electrical 1 03-14-2009 07:13 PM
almost caught fire in the ignition YJSXJ Street Jeep Forum 3 07-06-2008 02:44 AM
Jeep Caught Fire TG CJ7 Engines & Drivetrain 5 10-11-2002 11:57 PM
