Electric fan for my 2006 Tj. Worth it or not. 329.99 cost. - JeepForum.com
post #1 of 19 Old 02-17-2014, 01:35 AM Thread Starter
Cadreamin
Am thinking of adding a electric fan to my jeep to free up horsepower and torqu and add fuel economy. Anyone done this? Pros and cons? Thanks for your inputs!
Cadreamin is offline
post #2 of 19 Old 02-17-2014, 07:55 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
IMHO I would not make the swap unless the OEM fan died. There is some parasitic HP loss for every device an engine has to turn...but how much is that actually? I haven't found the answer yet myself. It would take a dyno test to come up with an accurate number.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 19 Old 02-17-2014, 07:57 PM
biffgnar
biffgnar's Avatar
There are many, many better ways to spend 330 on your jeep.
Romney in 2020!
biffgnar is offline
post #4 of 19 Old 02-17-2014, 10:36 PM Thread Starter
Cadreamin
Meaning find another way to spend 300 bucks it's not worth it? Or try it? It is a 4.0 6 speed 3.73 gears on 33x12.5 tires
post #5 of 19 Old 02-18-2014, 07:06 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Why replace an item that has a basic function that is in good working order is what we are saying.
I have an electric fan in my YJ.
In my case the water pump failed and my radiator was ready to give up the ghost anyway since it had a few small leaks and was partially clogged around the perimeter of the core. The rad and heater hoses were one heartbeat away from bursting also. I bought a new rad, cap, water pump and decided to go with a Zirgo fan kit.
BUT these parts on my engine were dead. Now if you got some $$$ to toss away be our guest! You will enjoy some MPG improvement, and increase in HP/performance. Mine seemed to be better....seemed....but I have no actual numbers for you.
BUT unless someone has done this and ran their engine before and after this mod on a dyno, the numbers you will hear about is not necessarily accurate. They are more like guesstimates than estimates IMHO.
post #6 of 19 Old 02-18-2014, 09:50 PM Thread Starter
Cadreamin
You make a really valid point. Nothing absolutely nothing is wrong with my jeep. I had a ford ranger v6 and had a rad. Leak. When it did being a mechanic I replaced the fan clutch, rad. Water pump, t-stats belt and hoses along with new coolant and a fresh oil change, and air filter. Maybe I will wait to have a problem before I create one. Just seemed like a good weekend project to save mpg. But it would be throwing money away at this point.
post #7 of 19 Old 02-20-2014, 05:12 PM
Timglide
On the up side, you can turn it off when temps are below zero and stay warmer inside. Also control the off and on while forging deep water so crap doesn't get sucked into your radiator fins. Also it can keep your engine cooler when wheeling at low rpm in hot weather. How much is all that worth?
Timglide is offline
post #8 of 19 Old 02-20-2014, 09:02 PM Thread Starter
Cadreamin
Valid points also, I looked online and found a 2 speed mark viii rad. Fan. It pulls over 4,000 cfm. I am going to install that unit on my ford f150, check mpg results after a month and decide if it would be worth the money to do the jeep. Gas ain't cheap and a couple mpg's for both vehicles could add up after a year or two. If I did do the fan on the jeep it would free up space in the motor compartment. Any recommendations on fans if I go with a electric fan for my 4.0 straight 6 wrangler for use here in California?
post #9 of 19 Old 02-21-2014, 06:13 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I run a Zirgo 16" electric fan that pulls 3300 CFM. It was a kit that everything needed for less than $200.00
Here is my setup for my '95 YJ 4.0;
http://home.comcast.net/~laybackman/Zirgo/Zirgo.htm
And here is what I did for my '89YJ 2.5;
http://home.comcast.net/~laybackman/89YJfansetup.htm
post #10 of 19 Old 02-21-2014, 06:46 AM
Louie4
Same consensus. If nothing is wrong then why do it?
On that note, I have a Taurus fan in my YJ but that's because I consistently had overheating on the trails at low speeds. I went through several radiators and determined my thermal fan clutches were crapping out on me.
So I found a junkyard Taurus fan for $16, got a Hayden thermostat for $20, and some relays for $40 or so and wired it up. Works great and replacement fans are cheap. I have an extra motor in case mine fails.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 19 Old 02-22-2014, 09:45 PM Thread Starter
Cadreamin
I like the coolant sensor set up rather than the bulb in the upper hose
post #12 of 19 Old 02-23-2014, 06:54 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Mine has worked well so far. Being that hot coolant from the engine hits the temp probe later the engine probably does warm up faster. In any event with a good radiator and clean water jackets the fan probably doesn't work much while you are driving at a constant speed as opposed to stop and go traffic.
post #13 of 19 Old 02-24-2014, 06:45 PM Thread Starter
Cadreamin
My issue was possible leaks were the bulb is inserted
post #14 of 19 Old 02-24-2014, 06:50 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Mine leaked also. So, I cut a shallow grove into the inside of the upper rad hose with a hacksaw blade. Then applied some Permatex to the inside of the hose and slapped it on the rad and attached the rad clamp making sure the probe wire was in that groove. It works just fine that way
post #15 of 19 Old 02-25-2014, 10:26 PM Thread Starter
Cadreamin
Hmmm. That bulb has to be at the top of the radiator? Or can it be inserted in the fins. .
