Electric cooling fans - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Electric cooling fans
Poison Spyder from CCOR!REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 04-11-2004, 05:02 PM   #1
chaseski85
Electric cooling fans (The GOOD and the BAD)????????
i have a 97 tj 4.0 L wanted to know if any one had any ideas for a cheep electric cooling fan upgrade? my fan clutchad died and needs replacing asap so if you know anything please i need your first hand experiance and even if there is a cheep way to do it???
thanks
chaseski85 is offline   Reply With Quote
Unread 04-12-2004, 05:51 PM   #2
yj_magnus
I've heard that the electric fans out of a Ford Taurus make for a nice fit, and aparently they free up a little horse power too.
Thats on my list of to do's.
[FONT=franklin gothic medium][B][SIZE=2][COLOR=sienna]See, its like my grandaddy use to alway say [I]"When hell is full, the dead will walk the earth[/I]"[/COLOR][/SIZE][/B][/FONT]
yj_magnus is offline   Reply With Quote
Unread 04-13-2004, 07:47 AM   #3
GreenReaper93
Ditto. It's a good swap. You can pick up a thermostat unit for it at JCW for around $20. It lets you dial in when you want the fan to turn on at whatever temp. you choose. Would also suggest wiring a kill switch for those "just in case" issues with crossing water.
GreenReaper93 is offline   Reply With Quote
Unread 04-16-2004, 01:46 PM   #4
Chondro
its on my list too...after a header. frees up some power and a little better gas mileage. hardcore off roaders say not to get them but i hate to break it to them, not everyone goes off roading or crosses 3 feet of water. WHO said that?!?! Bad monkey! bad monkey!
Chondro is offline   Reply With Quote
Unread 04-18-2004, 12:28 AM   #5
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
just wire them so you can shut them down while crossing. that's one of the plus sides to them. no worries about bending a fan blade into your radiator when you cross. the thing to watch for with the taurus fan is the high amperage draw. you're looking at almost 100 amps on initial start and a 33 amp continuous draw. running that, an amp, your off road lights, and all the rest will really put some strain on your charging system. look into an alternator upgrade soon after this mod or before it.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Unread 04-23-2004, 07:00 PM   #6
laybackman
laybackman's Avatar
thanks
I just did an electric fan convesion on my '89 YJ. It has the 2.5 4 banger in it. I went with a new fan but you could get a used fan if you wanted. here's the link:
http://laybackman.home.comcast.net/electric_fan.htm
There will be some changes but it isn't too hard.
laybackman is offline   Reply With Quote
