effect on mileage-gear change? - JeepForum.com
post #1 of 2 Old 05-01-2012, 07:29 AM Thread Starter
JeepLawyer
1979 CJ7
I have a 1979 CJ-7 with a 304-V8, and I am running KM2s which is a 35" on a 16" wheel, body lift 2", suspension lift 4" -- with standard gears right now. I am happy with the 9 mpg or so I get but ask:
If I have my shop change out the gears, how does this affect mileage, if at all? I think I understand that the engine runs at low rpms when you are running a larger tire and was just curious if there is a big change when you change gears which as I understand it will get the jeep back to his normal factory power after a gear swap to account for the larger tires.
Robert
JeepLawyer is offline
post #2 of 2 Old 05-01-2012, 10:00 AM
MoparXJ
1993 XJ Cherokee
Your gas mileage will improve if you get taller gears. Your engine doesn't have to work as hard to get those bigger tires moving.
MoparXJ is offline
1st gear change for T-18 jjlove Engines & Drivetrain 8 08-29-2007 05:49 AM
Dana 35 Gear Change 2qk4u Engines & Drivetrain 6 07-26-2007 02:46 AM
gear change on 33's? urwaker Tires & Wheels 6 04-26-2005 05:46 PM
tj gear change bnewsom General Jeep & Off-Road Equipment 4 08-22-2003 11:35 PM
Gear change but 2 what? TotalJeep General Jeep & Off-Road Equipment 3 06-26-2003 07:43 PM
