ECGS 8.8 rear axle options - JeepForum.com
post #1 of 7 Old 08-27-2013, 03:51 PM Thread Starter
jeffjeff
2010 JK Wrangler
kind of a newb here, looking for some advice. i have a 05 TJ that i replaced the rear end last winter (thing blew up, long story), and just did it stock because i found it cheap and had a guy cut me a deal on install. now i'm looking to do the upgrade (have the money and it's better to fix before it breaks) so i'm looking for some advice. there are lots of threads, but i can't find anything comprehensive enough.
i use my jeep as a dd, but occasionally take it out to the mountains and do some light wheeling when camping. i don't do it enough to spend tons of money on exclusively wheeling accessories, so i need to know what is really beneficial to a dd, and what is just extra for extremes...
i'm currently running 33s, so i believe i need 4.56 gears. from what else i've gathered, i don't think i need a locker (don't do that much wheeling) but i think i'll get positraction since it seems helpful and isn't THAT expensive.
what else do i need or should i look into? i think going sye is a bit expensive at this point, but if it would help i'd consider it. don't know much about control arms or shafts or flange/yoke, so advice there would be helpful.
thanks in advance!
jeffjeff is offline
post #2 of 7 Old 08-27-2013, 03:55 PM
sjones26573
What trans? What lift height? Are you regearing the front? Need more info.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 7 Old 08-28-2013, 06:28 AM Thread Starter
jeffjeff
2010 JK Wrangler
6sp manual. 3in body lift. definitely going to regear the front to whatever i get (currently running 3.07, which is rough considering the 33s).
jeffjeff is offline
post #4 of 7 Old 08-28-2013, 08:23 AM
sjones26573
Please cut that BL down. You certainly don't need an SYE for a BL
Jeep-Owner.com
post #5 of 7 Old 08-28-2013, 07:04 PM Thread Starter
jeffjeff
2010 JK Wrangler
actually thinking about removing it all together when getting this done (bought the jeep with it). would like to put a proper lift on it. any clue what a shop will charge me to remove it? hopefully not much if getting other work done.
jeffjeff is offline
post #6 of 7 Old 08-28-2013, 07:06 PM
sjones26573
Not too much but they require new bolts
Jeep-Owner.com
post #7 of 7 Old 08-28-2013, 07:25 PM
Shadownwpa
Will get expensive unless the bolts come out without breaking or tearing loose a captive nut.
Sent from AutoGuide.com Free App
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
