easy power - JeepForum.com
post #1 of 4 Old 07-29-2002, 09:35 AM Thread Starter
TDanks76
1979 CJ7
easy power
If you couldn't tell by the board I'm am looking for a easy way to get more power. I messed with the four banger enough and I'm ready for a engine swap. My question is what is the easiest engine conversion that I can do with out getting many new parts. If at all possible I would just like to replace the engine and nothing else. Then slowly work towards the axels and stuff. So what kind of six cylinder would bolt right up to my stock trans whatever that is.
I have a 1995 2.5L 5sp. i promise this will be my last post about engine swaps for a while.
CJ 7, with the good stuff.
TDanks76 is offline
post #2 of 4 Old 07-29-2002, 05:30 PM
errorinspelling
Look into the chevy camaro and pontiac firebird. Newer ones of course. The 3.4 Liters are nice. I am going a little different but here is a good place to be ching into. http://www.60degreev6.com/members/efixj and http://www.60degreev6.com/
The first is my site that is in progress but will be documenting my work on swapping in a 2.8 liter Multiport Fuel Injected Fiero engine into my 1984 Jeep cherokee. These engines are great since they are direct bolt up replacements for the 2.5 liter v6.
Eric Nelson
1984 Jeep cherokee
1986 Fiero GT v6 engine
errorinspelling is offline
post #3 of 4 Old 07-30-2002, 11:20 AM
4wheeler4CJ
4wheeler4CJ's Avatar
He has an AMC 2.5L 4-cylinder, not a GM motor or V6.
As far as a direct bolt-up, I'm not sure if the 4.0L will bolt up or not. If so, it is most likely your best swap.
4wheeler4CJ is offline
post #4 of 4 Old 07-30-2002, 04:52 PM
errorinspelling
Actually the AMC 2.5 (Not the Iron Duke) has the same bolt pattern as the GM 2.5 four cylinder and the 60 degree V6's (2.8 3.1 and 3.4 liter) The only thing that make the AMC 4 cylinder an AMC engine is the fact that they stuck a Ford computer and ignition module on it, It IS the GM block. Even the Chrysler made engines are the same bolt pattern. The 4.0's on the other hand are not a good swap due the the amount of body mods that need to be done, and that your need to have the AX15 Transmission which is a completely different bolt pattern. On 87 and later XJ's it's possible but incredibally difficult and would be easier just to buy a 4.0 XJ. Why? because they had to move the whole radiator and condensor core for the AC into the front grill area. The only poroblem I could see with a V6 in any of the newer Jeeps is if the dimple on the firewall where the fire wall rolls back into the transmission tunnel on the passenger side is still there. This was to accomodate the v6 Y exhaust pipe. If you like I can get a photo of this so you can see for yourself.
Eric Nelson
1984 Jeep cherokee
RE Easy-Ride VS Easy-Flex Redrum8675 Tires & Wheels 0 10-01-2007 10:10 PM
One more easy ? BIGNUTT Audio, CB & Ham Radios, GPS, & Electrical 7 06-05-2007 08:47 PM
Easy way to lift XJ? UF Red Rover Tires & Wheels 2 04-05-2007 09:03 PM
how easy... mossive Street Jeep Forum 16 09-16-2006 12:14 AM
Easy CB storage for the TJ/YJ JPMan-TJ Audio, CB & Ham Radios, GPS, & Electrical 17 04-15-2003 04:42 PM
