E-brake - Page 2 - JeepForum.com
post #16 of 25 Old 12-29-2012, 11:50 PM Thread Starter
Diefaster71
You are the effin man, how the heck did you find that???
Diefaster71 is offline
post #17 of 25 Old 12-29-2012, 11:51 PM
686keydragon
686keydragon is offline
post #18 of 25 Old 12-29-2012, 11:52 PM
686keydragon
Don't thank me just yet... I just noticed that it says it is for a D35, you should have a D44. Looks like it is the right part though.
post #19 of 25 Old 12-29-2012, 11:55 PM Thread Starter
Diefaster71
Its gotta be, it says its for 04 Rubicons, and Im not positive, but pretty sure they only came with dana 44's. Correct me if im wrong..
post #20 of 25 Old 12-29-2012, 11:55 PM
686keydragon
Worse case scenario make a call to 4wheelparts in the morning and see if it will work.
post #21 of 25 Old 12-29-2012, 11:55 PM
686keydragon
Agree, all the 04 rubi's should have d44's.
post #22 of 25 Old 12-29-2012, 11:57 PM Thread Starter
Diefaster71
Man I cant thank you enough for the help.
post #23 of 25 Old 12-29-2012, 11:59 PM
686keydragon
Anytime. Glad I could help.
post #24 of 25 Old 12-30-2012, 12:26 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That is not the correct part. That is the actuation lever for the parking brake function of Drum brake equipped rigs, yours is disc brake with a drum in hat rotor as has been stated.
For the record, both of the incorrect parking brake actuation levers will work on either Dana 35 or Dana 44 drum brakes because they are the same part, same drums, same everything including the housing end bolt pattern.
The part missing in the picture that the rectangular loop on the end of the cable hooks onto is Mopar Part number 05093392AA and is called the Parking Brake Adjuster Lever and is universal for both sides.
The part inside that goes between the ends of the parking brake shoes is called the Parking Brake Lever and there is a Right and a Left.
The right side is Mopar Part Number 0509334AA
The left side is Mopar Part Number 0509338AA
Last time I checked pricing, they were expensive for what they are. The same parts from an Explorer or a Grand Cherokee ZJ rear disc set-up are the same and will work. The part numbers I posted are for the TJ, Unlimited, Rubicon etc with rear disc brakes, 03 and up.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #25 of 25 Old 12-30-2012, 12:42 AM
686keydragon
I am very impressed. Thank you for the clarification.
