Driving a figure 8 - JeepForum.com
post #1 of 8 Old 06-22-2013, 02:59 AM Thread Starter
picflight
Driving a figure 8
I have seen it mentioned before, what I do not understand is:
1) What flaw or inconsistency this maneuver exposes? And how is it exposed?
2) Where should this maneuver be performed and what should be the gear configuration?
1996 Grand Cherokee 4x4 V8 5.2L Up Country Laredo
picflight is offline
post #2 of 8 Old 06-22-2013, 12:07 PM
LoveHate
if you have the all time 4x4, np249 t case then driving in a figure 8 will show if the viscous coupler is bad. if you drive in a 8 and the front wheels hop and bind then the vc is bad if everything is smooth then your vc is good.
Just Enjoying Every Puddle
Built Not Bought #693
LoveHate is offline
post #3 of 8 Old 06-22-2013, 12:11 PM Thread Starter
picflight
Hop & bind, how does that feel to the driver? I guess I am asking what is hop & bind?
I am guessing this maneuver is done on a flat surface at slow speed with 4 LO engaged?
post #4 of 8 Old 06-23-2013, 04:12 PM
Evildriver-3
When you make a hard right turn or left you'll feel the jeep become jumpy like, or chatter like, anything other than smooth.
You most likely have awd and the 249 unless the previous owner changed it already.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #5 of 8 Old 06-23-2013, 05:16 PM
LoveHate
no don't do it in 4lo just in the regular 4 hi. if its anything but smooth that's bad.
LoveHate is offline
post #6 of 8 Old 06-23-2013, 10:38 PM
Evildriver-3
In 4lo it doesn't have any issue making a hard turn, like if you turn the wheel full lock and try and make a circle ?
]=Supershafts=[
post #7 of 8 Old 06-24-2013, 12:27 AM Thread Starter
picflight
Mine is Quadratech AWD, all stock with 195K. I did the figure 8 today in AWD mode, didn't notice anything unusual.
post #8 of 8 Old 06-24-2013, 09:14 AM
Evildriver-3
Did you do the turns right after starting.it up or after.you drove it and everything is warm, cold t-case won't act up, you have to be at temp and then just make any turn at full lock
]=Supershafts=[
