Drivetrain noises - JeepForum.com
post #1 of 6 Old 10-23-2011, 11:14 AM Thread Starter
ethansmith1010
Drivetrain noises
I have a 99 wrangler sport with a four inch lift and 35s on it. I haven't had it very long and it makes a lot of pops and clunks when I'm backing up or turn and I'm not Turing sharply just wanted to know how normal this is. Any help would be awesome
ethansmith1010 is offline
post #2 of 6 Old 10-24-2011, 11:57 AM
Danny0717
Is make sure those tires aren't rubbing the front bumper or fenders. Start there and also popping n clunking while turning is look into ball joints or just bad suspension parts in general. And as far as backing up id look into the u joints on the driveshafts. They can make some noises on ya.
Danny0717 is offline
post #3 of 6 Old 10-24-2011, 04:05 PM Thread Starter
ethansmith1010
Cool thanks a lot yea I just need some ideas on where to start
post #4 of 6 Old 10-24-2011, 04:36 PM
Shmee
my jeep has this pop and clunk the inspection result says its the swivel that's loose and need to be replaced, nothing expensive.
Shmee is offline
post #5 of 6 Old 10-24-2011, 08:22 PM
Danny0717
Mine as well clunks n pops too. But another common problem is those stab links that connect to the drag link can still be connected but inside of the little boot its kinda like a ball joint they separate and clunk against eachother when hitting bumps n turning n what not. Best way to check is put a floor jack under it jack it up to raise it apart n slowly let it back down to see n hear for the noises.
post #6 of 6 Old 10-25-2011, 11:41 AM
jeepn4life92
check to make sure all suspensions and steering end links (no matter what kind of link, johnny joint, etc) to make sure all bolts are tight, they can become loose just from common driving. this same exact scenario occured after an offroading trip i and some friends took to rausch creek...the axle side bolt in the lower control arm on the front axle of my friends tj came loose and as a result, the control arm clunked around a bit from the loose bolt only when taking turns and stopping without stopping hard...just enough for the arm to move a bit. have a friend watch all the components while you roll forward and back...thats how we found what it was.
good luck
jeepn4life92 is offline
Cj5 drivetrain GROUNDHUGGER Engines & Drivetrain 0 02-23-2011 08:20 AM
DriveTrain Noises while turning at slow speeds Rich235 Engines & Drivetrain 0 08-06-2009 02:16 PM
ZJ Noises! AH Draaier Engines & Drivetrain 0 09-02-2008 06:03 PM
Drivetrain? bmx_hb_guy Engines & Drivetrain 2 01-17-2007 01:33 PM
RE BB noises Torquemeister Tires & Wheels 11 01-24-2006 01:18 PM
