Driveshaft Vibes - JeepForum.com
post #1 of 3 Old 12-04-2012, 08:39 AM Thread Starter
rhoadsWJ
Driveshaft Vibes
My front driveshaft once I start getting above 25mph starts vibrating real bad. When i first got me the jeep it didnt do it, but I had to replace the U joints and put the shaft back in it started to vibrate. I removed the drive shaft again and drove without it and it doesnt vibrate. The drive shaft is from IRO and it a double cardon. Any suggestions on what I gould do to get rid of the vibration.
P.S.
There is a 4" Long arm lift kit installed onto the jeep.
I have a 1999 Jeep Grand Cherokee Laredo 4.0 V6
rhoadsWJ is offline
post #2 of 3 Old 12-04-2012, 07:17 PM
jrmboat
When you had it out of the jeep did you pull it apart at the slip joint. If so, you might not have put it back together in phase.
jrmboat is offline
post #3 of 3 Old 12-04-2012, 09:13 PM
jokerchief462
Look at the driveshaft and see if you see any weights on it from balancing, if not may not bebalanced. Local shop <$75 is what we pay out here. The above is also correct if you have had both pieces apart.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
