drive shaft vibrations after axle swap - JeepForum.com
post #1 of 11 Old 04-06-2012, 12:21 AM Thread Starter
jeepordie10
So i just swapped in a ECGS ford 8.8 everything went great until i hit about 40mph and i could feel some drive vibrations. I put the track bar in the lowest hole because when i lifted the axle up all the way thats the hole that lines up... My question is did i get it in the right hole (hahaha funny) or is it from the drive shaft?
98 jeep tj
4" adjustable short arm RE lift, 2" body
tcase drop, motor mount lift, SYE and tom woods driveshaft...
jeepordie10 is offline
post #2 of 11 Old 04-06-2012, 05:32 AM
Technohead
The track bar does not have much to do with it.
Did you adjust the pinion angle?
-Eric
Technohead is offline
post #3 of 11 Old 04-06-2012, 09:47 AM Thread Starter
jeepordie10
going to go measure pinion angle now.
post #4 of 11 Old 04-06-2012, 10:49 AM Thread Starter
jeepordie10
tcase angle is 20 and the axle is at about 24... would 4 degrees make a huge difference? My Rubicon Express adjustable control arms are rusty and i couldnt loosen the nut?
post #5 of 11 Old 04-06-2012, 11:06 AM
Technohead
With an SYE the pinion should be pointing directly at the t-case output yoke. In other words zero degree angle between the driveshaft and pinion. As little as 2-3 degrees off can make a difference.
Do you really need the t-case drop with the SYE? Seems like a waste of ground clearance to me.
P.S. Good luck with the control arms. They don't like road salt at all. I used to wash mine and slather them with grease weekly during the winter months.
-Eric
post #6 of 11 Old 04-06-2012, 10:01 PM Thread Starter
jeepordie10
Alright got them off and adjusted.. I also noticed that my brake pads are rubbing on the rotors more then they should be. when i drove it it sounded like a train wreck, could this be a bad brake bleeding or caliper piston stuck?
post #7 of 11 Old 04-06-2012, 10:05 PM
nitecop
since you have a tom woods drive shaft you have most likely seen these
Here is a diaghram of the Proper Geometry For the 2 types of drive shafts.
3 joint drive shaft. (A.K.A. double cardon joint and a single joint shaft)
A shaft with 2 single joints
(photos from Tom Woods Drive shafts)
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #8 of 11 Old 04-06-2012, 10:23 PM Thread Starter
jeepordie10
yea i got that figured out, but just need to figure out my brake problem ^^^
post #9 of 11 Old 04-07-2012, 09:17 AM
Technohead
Probably the calipers. A couple weeks ago I did just pads & rotors on my new rig then two days later driving down the highway the smoke started pouring from one of the rear brakes. Caliper was stuck. Cutting corners does not save anything. If I were you I would have done pads, rotors, and calipers at the same time as the axle. And oh yea, don't forget to paint the calipers red!
-Eric
post #10 of 11 Old 04-07-2012, 11:49 AM Thread Starter
jeepordie10
all new pads rotors and calipers got it fixed it was stuck. Got my control arms back on and took it for a drive, still get a little vibrations but not as much as before. The pinion is at 23 and the driveshaft is at 22... Since its a bolt in axle from ECGS the guy said the pinion axle is set to "factory with the lift" so ill have to bring the control arms in a few rotations?
post #11 of 11 Old 04-07-2012, 02:07 PM
Technohead
Originally Posted by jeepordie10 View Post
Since its a bolt in axle from ECGS the guy said the pinion axle is set to "factory with the lift" . . .
I have no idea what this means. All they can do is weld the control arm brackets on at the same orientatation as the stock axle. There is no way they can know what lift you have, how long the control arms are, which t-case you are running,etc. Hence there is nothing they can do when building the axle that will help get the pinion angle correct.
Off by a degree does not sound bad to me. I typically use the eyeball method. And besides, a little vibration is all part of the Jeep experience!!!
-Eric
SYE/Drive Shaft CWGuns General Jeep & Off-Road Equipment 2 04-20-2011 11:36 AM
what drive shaft for this SYE headstrong50 Engines & Drivetrain 4 03-12-2010 12:55 PM
CV Drive shaft & Axle questions Wifs'98XJSport Engines & Drivetrain 6 01-27-2009 03:47 PM
drive shaft help?? 360wrangler Engines & Drivetrain 5 12-30-2006 10:22 PM
Will this shaft cause vibrations? HMTwin Engines & Drivetrain 2 08-25-2006 11:36 AM
