Drive shaft question, please help... - JeepForum.com
post #1 of 6 Old 01-01-2013, 08:31 PM Thread Starter
Diefaster71
I have an 04 Rubicon and recently aquired a case of "angry sparrows" with my front DS, so while I had it broke down I decided to go ahead and replace all three ujoints, and obviously the CV socket yoke that was making the noise. The problem starts when I went down to Napa to see if they had the right ujoints and CV socket, they had the ujoints and not the CV socket, but they showed the DS as having two different types of ujoints, the two in the back on the double cardan as being the same, but the front yoke where it connects to the front axle as being different, the ones I pulled out are all the same size. This leads me to believe either they are screwed up, or when I bought the Jeep, it had a previously different front DS installed. That or Im just retarded, in any case, I need help. If you can take a look at the pictures, do I need 1310 ujoints, or 1330. By looking at pictures of 1310's and 1330's the 1330's look more like mine with the longer neck. Also, as for the CV socket yoke, dont have any clue which one I need. Ive looked at STU's write up on overhauling a front DS at http://www.stu-offroad.com/axle/driv...iveshaft-5.htm, and was wondering if those are the right part numbers for mine. Im 95% sure, just need the clarification. Thanks for the help guys.
Cody
Diefaster71 is offline
post #2 of 6 Old 01-01-2013, 08:55 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
You really arent expecting us to be able to tell the difference between a 1310 and 1330 u joint from those fotos are you?
If you cant measure the ones you have, just take them to a parts store and compare them to whatever they have.
There are numerous sites online though, that list the measurements for all u joints. Diameter of cap, length of cap, blah blah blah.
Such as this one, that also explains the ins and outs of u joints etc. First one that came up when I used Google.
http://www.therangerstation.com/Maga...08/ujoints.htm
As far as the CV socket, that may be an online deal, and not available at your local parts store etc.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 6 Old 01-01-2013, 09:14 PM Thread Starter
Diefaster71
I actually have already checked out that site, and by looking at the picture that has the different ujoints in a line and describes them from left to right starting with a 1310 with a 1330 after that, the neck on the 1330 is noticeably longer, just like the one in my picture, you don't need a micrometer to see the difference, you can tell by just looking at them. Which brings me back to the question, why the heck would my jeep have a front DS with 1330 ujoints, is that a stock thing, what's your guys take on this. I bought the jeep like this and I need some help decoding what the previous owner did to it.
post #4 of 6 Old 01-02-2013, 11:44 AM Thread Starter
Diefaster71
I said screw it and today I brought the front DS by a machine shop and the guy just glanced at it and told me it was a 1330. It apparently needs some work on the slip yoke as well so I just left it with him to take care of it for me and fix the slip yoke and put in the ujoints and CV center bearing. I hate having other people do work for me.
post #5 of 6 Old 01-03-2013, 07:09 PM
jokerchief462
Yeah but sometimes it is better to get a pro to help out a little. Don't feel bad we all have that day come by.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 6 Old 01-03-2013, 07:41 PM Thread Starter
Diefaster71
Yeah it ended up being a pretty penny but the guy did an amazing job and I'm really satisfied with the end result. It sucks but I have to admit it was worth it.
