Drive shaft problem - JeepForum.com
post #1 of 7 Old 07-10-2013, 02:49 PM Thread Starter
austinp2
Hey guys, so I have a 93 yj and the first U joint my rear driveshaft broke. The whole driveshaft fell out and tons of oil leaked out the back. I am unsure with what oil to replace it with... Is it transmission oil, or is it a different kind of oil. Please help!
austinp2 is offline
post #2 of 7 Old 07-10-2013, 03:03 PM
Evildriver-3
depending which t-case it may just be a trans fluid and not a gear type oil. Check the end yoke that the centering tabs aren't broken
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 7 Old 07-11-2013, 10:26 AM
biffgnar
biffgnar's Avatar
For pre-96/97 231s with stock output if the driveshaft is off all the TC fluid will drain out. Pretty sure ATF+4 is what is spec'd for refilling that 231.
Romney in 2020!
biffgnar is offline
post #4 of 7 Old 07-11-2013, 03:19 PM
GilaMtnJeep
GilaMtnJeep's Avatar
ATF+4 goes in the t-case.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 7 Old 07-12-2013, 12:49 AM
jnicewan
The spec fluid depends on who you want to listen too, Jeep/chrysler naturally preferred their fluid and back then it was ATF+2 & +3, New Process simply called for ATF, Chevrolet (NP231C) like chrysler preferred their fluid and back then it was Dex II & III. And if Ford used this case I bet they would've spec'd Mercon. Other fluids people have successfully used are motor oils from 5w-30 to 30W. Since ATF+4 is the current fluid that superceded the older ones, it is a synthetic based ATF, its probably the better fluid to use but not needed.
Dry fill capacity is less than 2 qts, or closer to 1.6 qts. I would go ahead and drain whats left and start with all new fluid.
jnicewan is offline
post #6 of 7 Old 07-13-2013, 09:53 AM Thread Starter
austinp2
Ok sounds great. One more thing. Is it the same for the transfer case or is it a different fluid?
austinp2 is offline
post #7 of 7 Old 07-13-2013, 11:47 AM
jnicewan
I dont know what your asking, but the t-case takes auto trans fluid (ATF). Nothing special needed, get cheap ATF fluid, Dex/Merc, or put ATF+4 in it.
jnicewan is offline
