drive shaft noise? - JeepForum.com
post #1 of 3 Old 06-19-2013, 01:22 AM Thread Starter
gtrampuh
drive shaft noise?
96 JGC L, the guy I bought the Jeep from said the front drive shaft seized up. He replaced the u-joints but now when I install it there is a thumping noise. With the drive shaft out there in no noise at all. The u-joints move freely and feel smooth with no play. The cv joint seems to be ok but I suspect that that may be the problem. You cant buy a replacement cv for it, you have to buy the whole axle. $$$ Does anyone know if there is a kit that I can still use my axle and change the cv joint to u-joints? Or does anyone have an idea what could be causing this thumping noise?
Thanks
gtrampuh is offline
post #2 of 3 Old 06-19-2013, 01:45 AM
xrunndonex
1994 ZJ
Thanks
Sounds like the shaft could be bent. That's the only thing I can think of.
xrunndonex is offline
post #3 of 3 Old 06-20-2013, 01:33 AM
Evildriver-3
The front axle joints can be transmitting or there is another issue with the diff or t-case, if the rzeppa is moving fine then i'd leave it.
If you really want to change it which i don't recommend since the rzeppa isn't a bad thing.
See your local driveline shop if you need or think you need a new rzeppa head or you want to change to the u-joint cv head, i'd leave it as is and let your local driveline shop have a look at it, but i think you may have a issue and the front shaft may be the link transmitting it.
Seeing your local driveline shop will save you from having to but the entire shaft or a new shaft
. You have the rzeppa at the diff and the cv head at the t-case ?
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
