drive line vibration please help - JeepForum.com
post #1 of 3 Old 04-06-2013, 09:57 PM Thread Starter
standfast85
So I have installed the re 6025 with new leafs.. I got it all done .. not to bad to install.. well I went for a ride to get an alignment and there is some vibration coming from the rear.. I didnt install shims and I tried tc drop but the studs are redic.. so can I get away with shiming until I get my sye..?? And if so how do I set the angle.. my rear axle seems to be pointing up to the tc.. is it not pointing up high enough or does it need to be pointing straight like the tc.. its seems like its not up high enough and is binding because when Im accelerating it vibrates then if I let off it makes kind of a grinding noise???? Please help
standfast85 is offline
post #2 of 3 Old 04-07-2013, 06:07 AM
Evildriver-3
Maybe the joints bad if it's making a grinding noise, vibe underload is angle
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 3 Old 04-07-2013, 07:50 AM
GilaMtnJeep
GilaMtnJeep's Avatar
How much lift? Vibes could be angles, wear, or both. If you think you are binding, check your yokes, binding will show as contact there and is bad. If you have no sye then the pinion and t-case output shafts should be close to parallel. With an sye the pinion points at the t-case. Go to Tom Woods web site and look in the tech section, it explains it all.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
