double double cardan? - JeepForum.com
post #1 of 3 Old 12-11-2006, 08:32 AM Thread Starter
Vacant Stare
Just wondering if anyone has ever seen/heard of a driveshaft with double cardans at both ends? It would have to be a fairly long driveshaft to begin with to pull it off, I would think...
Vacant Stare is offline
post #2 of 3 Old 12-11-2006, 12:49 PM
KrazyGimp
1982 CJ5
Here is a rebuild for one, so I can only assume that they do exist...
http://www.rblewis.net/personal/bronco/driveshaft/
Here is a little info on the different styles...
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #3 of 3 Old 12-12-2006, 04:32 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A double double cardan shaft would be usefull where the transfer case yoke and axle pinion are out of alignment on two separate planes. For example running a "centered yoke" transfer case (like a Dana 300 or NP231) with a rear axle having its diff offset to one side (axle intended for a Q-trac). Since both ends of the driveshaft would be "self-cancelling", you wouldn't have to really worry about matching angles of the tc or diff (within reason).
BESRK is offline
Double Cardan rebuild EddieB606 Engines & Drivetrain 3 10-04-2011 11:06 PM
double cardan at both ends of drive shaft? Vacant Stare Engines & Drivetrain 5 10-16-2007 09:48 AM
1.5 din --> Double din? Mark v Audio, CB & Ham Radios, GPS, & Electrical 0 05-27-2007 06:50 PM
Double Din help please froggo27 Audio, CB & Ham Radios, GPS, & Electrical 4 02-23-2007 03:59 PM
Double DIN? dejablu311 Audio, CB & Ham Radios, GPS, & Electrical 6 06-08-2005 10:37 PM
