double cardan at both ends of drive shaft? - JeepForum.com
post #1 of 6 Old 10-15-2007, 08:52 AM Thread Starter
Vacant Stare
I was thinking about the cascade effect of installing an SYE- adjusting the rear pinion angle, which throws the shocks, trackbar, and spring cups off, and wondered why we don't instead use a drive shaft that has a double cardan at each end and leave the rear axle where it is?
just curious.
Vacant Stare is offline
post #2 of 6 Old 10-15-2007, 09:32 AM
RLD831
RLD831's Avatar
I dont think two double cardans would work that way. It would be shaped like an " S " if you used the stock angles. They need to be angled in the same direction like an " r " to work in the way you are describing.
RLD831 is offline
post #3 of 6 Old 10-15-2007, 04:03 PM
supraman1990
supraman1990's Avatar
1980 CJ5
Tom Woods does it.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #4 of 6 Old 10-15-2007, 07:28 PM
mike_dippert
hodophobic
mike_dippert's Avatar
i'm curious about this too. my TT and OME lift are getting closer to the top of my list, i don't really want to use adjustable arms for the reasons you listed.
mike_dippert is offline
post #5 of 6 Old 10-15-2007, 11:36 PM Thread Starter
Vacant Stare
Well I did a little research on this today, and the only reason I can find not to do it is cost. a double cardan joint does add to the cost of a custom driveshaft. I found this little blurb at the Tom Woods site:
"Multiple Double Cardan (CV) drive shafts are built using modified off the shelf components. This configuration will typically add about $180 to the cost of a more conventional CV and may require using a custom adapter flange."
So it sounds like you'd need a pinion flange for the rear axle to replace the yoke. I found one for Dana 44's for $99.
The only other possible drawback I can see is that having the pinion point forward instead of angling up toward the t-case might make it more likely to snag on things.
It's probably 'overkill' for a mild lift, but I do like the idea of avoiding all the annoyances that come with changing the pinion angle.
post #6 of 6 Old 10-16-2007, 10:48 AM Thread Starter
Vacant Stare
I called Tom Woods this morning to get their take on this. They brought up a few things I hadn't thought of.
Double cardan joints are longer than u-joints. On a SWB jeep, there just isn't enough driveshaft length to stuff 2 in there.
Double cardan joints are heavier than u-joints. You could end up with a drive shaft that's so heavy it's hard to balance. Not good for freeway driving.
There is a double cardan pinion yoke for Dana 44's though, so the flange wouldn't be necessary.
It's always good to talk to the experts.
Double Cardan rebuild EddieB606 Engines & Drivetrain 3 10-05-2011 12:06 AM
CV Drive Shaft GDTIME Tires & Wheels 0 07-28-2008 06:21 PM
Drive Shaft Paul08Wrangler Engines & Drivetrain 2 02-12-2008 12:10 PM
double double cardan? Vacant Stare Engines & Drivetrain 2 12-12-2006 05:32 PM
Drive Shaft DIESEL Tires & Wheels 2 04-27-2004 07:26 AM
