Do I need to set my gear lash? - JeepForum.com
post #1 of 4 Old 10-24-2011, 12:28 PM Thread Starter
squarelight94
I installed a lunchbox locker in my front d30 but had to remove the carrier and ring gear because it was the think ring gear. I didn't touch the pinion at all. I installed the locker then reinstalled the carrier and torqued the bearing caps to spec. Will my gear lash be altered?
I've checked with other forums and all of them removed the pinion and therefore need to set the lash. I cannot find the answer to my specific situation. Please help, I want to drive my 94 YJ again! Thanks
squarelight94 is offline
post #2 of 4 Old 10-24-2011, 01:56 PM
mdm
Farm Wheeler
You reinstalled the same ring gear? You reinstalled the same bearings, shims, and caps on the same sides they came from? Then no, you don't have to check anything. It is still the same as it was before you took it apart, however good or bad that was.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 4 Old 10-24-2011, 02:27 PM
jalves3
jalves3's Avatar
1967 CJ5
You should make sure it is the same as before. If it changed, you did something wrong and can pull it back apart before any permanent damage is done.
"Peace is that brief glorious moment in history when everybody stands around reloading" Thomas Jefferson
"Nearly all men can stand adversity, but if you want to test a man's character, give him power" Abraham Lincoln
jalves3 is offline
post #4 of 4 Old 10-24-2011, 02:59 PM Thread Starter
squarelight94
Yes, this is what I did. Thanks for the insight. I know ideally I should check it but I won't be able to for a couple weeks. Thanks
valve lash ticking tenntom3567 Engines & Drivetrain 1 09-30-2011 05:56 PM
D44a Gear pattern help - calling all gear install experts BLACKzj52 Engines & Drivetrain 38 06-21-2010 06:37 PM
HP30 Gear pattern help - calling all gear install experts BLACKzj52 Engines & Drivetrain 10 06-13-2010 09:01 PM
Valve Lash TxOWeb Engines & Drivetrain 1 02-26-2007 08:40 PM
Limited Slip Gear Oil VS Regular Gear Oil CanukYJ General Jeep & Off-Road Equipment 8 04-10-2004 06:04 PM
