Do I need gasket sealer on a new oil pan gasket? - JeepForum.com
post #1 of 5 Old 10-18-2008, 03:03 PM Thread Starter
jeepster93
jeepster93's Avatar
I am changing the rear main seal and am about to re-install the oil pan. The old oil pan gasket did not have any sealer on it except around the timing chain and in the corners in the rear of the pan.
Using a 1 piece gasket.
Do I just copy what was on there before?
Or...
Follow the Chilton's, which says to coat the gasket on both sides. The Chilton's does show using a 4 piece gasket though.
How about thread locker on the oil pan bolts?
The Chilton's also says 10 pounds of torque on the oil pan bolts...seems low???
jeepster93 is offline
post #2 of 5 Old 10-18-2008, 10:34 PM
mr4x4
thats what I did on the one peice gaskets
the three piece gaskets you have to coat the whole thing
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #3 of 5 Old 10-18-2008, 10:41 PM
mr4x4
almost .forgot be very carefull when you go to bolt up the oil pan sometimes the rear of the gasket the (trans side)
it tends to fold a little when you start to bolt it up and it will cause it to leak
you wont know if it worked untill you fill it and start the engine
the last one I did I had to take it apart twice because it didnt seat right in the rear
mr4x4 is offline
post #4 of 5 Old 10-18-2008, 11:03 PM
cvd
cvd's Avatar
My Haynes TJ manual says the oil pan bolts should be torqued to 84 inch/lbs (7 ft/lbs). So 10 ft/lbs doesn't seem low for yours.
cvd is offline
post #5 of 5 Old 10-19-2008, 12:18 AM
willness33
Agree.
I use gasket sealer only to help hold the gasket in place while you're getting all the bolts in. Makes the job a little easier, IMO.
willness33 is offline
Fel-Pro Gasket Kit th3t1nm4n Engines & Drivetrain 2 12-14-2009 08:41 AM
4.0 Efi Intake On A 4.2....what Gasket??? bambam Engines & Drivetrain 1 08-27-2009 10:28 AM
4.0L head gasket? BlackedOut98 Engines & Drivetrain 2 01-13-2009 03:12 PM
258 Head Gasket Job BUDGETBEAST Engines & Drivetrain 6 07-30-2007 06:03 AM
Fel-Pro Gasket Set for 4.0L I6 Brian's 97 ZJ Engines & Drivetrain 1 06-03-2004 07:40 AM
