distributor question on a 99 inline 6 4.0 - JeepForum.com
post #1 of 3 Old 05-08-2014, 11:57 AM Thread Starter
jeepsareballin
I recently had my inline 6 4.0 rebuilt. We took it out of my 99 wrangler ourselves. That was no problem but now that were puttin it back in I want to make sure that I put the new distributor in correctly before I get it all the way back in only to find out that I did it wrong.
jeepsareballin is offline
post #2 of 3 Old 05-08-2014, 07:47 PM
greenmachine99
greenmachine99's Avatar
You'll be able to get it running, but the fuel sync will need to be set at the dealer or someone with a snap on scanner. The distributor on yours doesn't tell the spark plugs when to fire, the pcm does that via crank sensor. The distributor tells the injectors when to fire via cam sensor under the distributor cap. You cannot set this with a timing light.
greenmachine99 is offline
post #3 of 3 Old 05-14-2014, 07:12 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Ok. First off IF the dizzy was not put in properly it may not fire at all.
Assuming the engine builder put the timing chain kit in properly and you installed the dizzy properly this engine should run off of the factory presets in the brain.
Then as it goes from open to closed loop mode over time the brain learns from the inputs from the sensors and averages out the amounts.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
