Differential problem I think?? - JeepForum.com
post #1 of 5 Old 12-25-2011, 09:21 PM Thread Starter
hdrocknroll
Differential problem I think?? What do you think?
I have a whining in the rear.
I just bought this Jeep December 3, 95 grand Cherokee 4.0, I have been doing a lot of repairs.
It had a bent rear left axle, replaced axle with good junkyard axle new bearing and seal.
Before that I don't know if the rear end was whining because the left rear bearing was making so much noise.
Now I thought it might be making too much noise, whining at lower speeds, but today was first day I took it out on freeway, and when I got it up to 70 75 80 it was whining big-time, wines most as you accelerate, a lot less when you let off.
Is definitely coming from the rear not the tranny.
When I did the rear axle I checked the fluid before I opened it up and it was only slightly low, the fluid was black.
I noticed that it had been leaking some around the pinion seal. The new oil I put in was Mobil1 Synthetic Gear Lubricant LS 75W-90
It has the command Trac four-wheel drive, the rear end is a Dana 35C, does this require an additive?, I did not put any additive in.
So! Is my right rear bearing bad making that noise? I doubt but I thought I should ask. Or is it my pinion gear? Or other parts in the rear end? Or drive shaft u joint maybe?
From what I understand it is probably not a good idea for me to try to replace the pinion gear, so how much will it cost me to have this done?
How many miles can I drive it this way without destroying something?
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 5 Old 12-26-2011, 03:03 PM Thread Starter
hdrocknroll
I appreciate your opinions !!!!
post #3 of 5 Old 12-27-2011, 09:00 AM
t2c1
It is more than likely a gear pattern issue since the noise changes under acceleration and coasting. If it was a bearing you could change the sound by slightly turning left to right and changing the loads on each axle bearing.
Member of NA4WDA
Co-owner Total Off Road Experience off road park
www.tore.ws
t2c1 is offline
post #4 of 5 Old 12-27-2011, 09:01 AM
t2c1
Could also be a pinion bearing.
Member of NA4WDA
www.tore.ws
t2c1 is offline
post #5 of 5 Old 12-29-2011, 04:55 PM
accord23
Sounds like you have the exact problem i got!! I'm thinking of replacing my Dif with one from a Junkyard next week i just can't stand the whining noise. My buddy has had the whining from his ZJ for a couple of years now, and its still going strong.
accord23 is offline
differential
differential oil help please bergar65 Engines & Drivetrain 2 10-31-2011 09:11 AM
differential oil.... bergar65 Tires & Wheels 0 10-28-2011 05:11 PM
Differential Help Bobbis Engines & Drivetrain 1 12-11-2010 02:27 AM
HOT differential?? bvectra Engines & Drivetrain 0 01-06-2010 03:36 PM
Did my Differential go out? Samgler Engines & Drivetrain 2 12-09-2007 11:07 AM
