differential identification - JeepForum.com
post #1 of 9 Old 05-28-2010, 05:43 AM Thread Starter
Djay101
Was wondering how to identify the differential I have on my jeep, i know its a dana 35 but not sure if it has limited slip or not... how do I tell?
""" Its a jeep thing, you wouldn't understand!"""
""" Jeep... is it in you? """
my build thread...
Djay101 is offline
post #2 of 9 Old 05-28-2010, 07:31 AM
Pillswoj
Not likely to have Limit slip in an SE and even if it did it probably wore out, the factory units don't last much over 80,000 km.
Friends don't let Friends run Bosch
Pillswoj is offline
post #3 of 9 Old 05-28-2010, 01:09 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Limited slip was not an option for a '98 SE.
There are a couple ways to verify if a limited slip was installed, either by a previous owner or maybe even a factory mistake:
1. Raise the rear tires off the ground. Spin one tire and watch how the other tire turns If the other tire turns in the same direction, you have a functional limited slip or a locker. If the other tire turns opposite or remains still, you have an open diff or a limited slip that is no longer functional. Sometimes you have to put a little resistance on the opposite tire in order for the limited slip clutches to grab and turn the opposite tire in the same direction.
2. The best way to know for sure is to open the diff cover and look at the shape of the diff case.
Open on left, Limited slip on right:
Wheelin98TJ is offline
post #4 of 9 Old 05-28-2010, 05:13 PM Thread Starter
Djay101
see my axle was replaced and was off roading and seems like both tires were spinning going in mud and up a rocky hill... in sand both rear tires were spinning, yet in the winter only one tire spun in loose snow...
my build thread...
Djay101 is offline
post #5 of 9 Old 05-28-2010, 08:34 PM
Wheelin98TJ
JEEP FREAK
An open diff spins both wheels under certain circumstances. When the traction is equal, both tires turn.
And a limited slip will only spin one wheel in certain situations. Once the traction difference between the 2 tires becomes too great (for example 1 tire on snow, the other on ice) a limited slip will behave just like an open diff. That is why most people who wheel their Jeeps prefer a locker. So you always have both wheels turning.
In other words, its hard to tell for sure if you have limited slip based on what tires are spinning and when.
post #6 of 9 Old 06-10-2010, 05:12 PM Thread Starter
Djay101
not origional rear axle in my jeep
my build thread...
Djay101 is offline
post #7 of 9 Old 06-10-2010, 05:14 PM Thread Starter
Djay101
apparently the P.O. daughter got a parts jeep and it was a Rubicon, newer and bigger... the drive train was all that was good left in it, so she got the axles seitched in the rear as the origional broke...
my build thread...
Djay101 is offline
post #8 of 9 Old 04-08-2013, 04:01 PM
Captainak
1982 CJ7
https://plus.google.com/photos/11645...83655447386049 or
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
post #9 of 9 Old 04-12-2013, 02:20 AM
tytrev
I had an 01 TJ that had a metal tag on one of the rear diff bolt warning to only use limited slip oil...that's how I found out I had one.
97 TJ SE: Building for medium trails
62 CJ5 Willys: Restoring to original...well close to original
Who cares about my other cars? They're not JEEPS!
tytrev is offline
Axle identification RUBtjICON Engines & Drivetrain 8 04-22-2009 02:40 PM
Need help with engine identification Lunchbox2011 General Jeep & Off-Road Equipment 1 12-13-2008 02:10 PM
Identification Help Powerplay Tires & Wheels 2 11-20-2008 05:00 AM
axle identification nudomucho Engines & Drivetrain 5 09-03-2008 06:39 AM
Ford 8.8 Identification Tag lukera Engines & Drivetrain 3 10-13-2006 08:36 AM
