Diff vent tubes and where are they? - JeepForum.com
post #1 of 6 Old 03-11-2007, 10:16 PM Thread Starter
ElvisV04290
ElvisV04290's Avatar
So I know where my front and tranny vent tube is, but where does the rear diff vent too and why can't i just plug it to keep water out? thanks.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #2 of 6 Old 03-13-2007, 10:09 AM
frankiefire702
The rear vent tube I believe is ziptied to your fuel filler hose.
06 tj locked on 36's.
frankiefire702 is offline
post #3 of 6 Old 03-17-2007, 10:45 AM
xyz123
Super Senior Member
Frankiefire702 is correct. If you pull the plastic cover down at the bottom corner you can see it...at least on the TJ..its likely the same on the yj..
xyz123 is offline
post #4 of 6 Old 03-17-2007, 06:48 PM Thread Starter
ElvisV04290
thanks guys, I'll take a look tomorrow.
post #5 of 6 Old 03-17-2007, 08:09 PM
jason m
Nothing but the facts
jason m's Avatar
you cant plug them because they create pressure while in use and you will blow out your axles seals. did you ever open up a final drive on an excavator, they have no vents and if you open it up without letting the pressure blead you will take a bath in the oil. the point is any gear on gear creates pressure and if its not vented it will find a way out unless its final drive witch is made not to vent, jason.
jason m is offline
post #6 of 6 Old 03-24-2007, 08:35 PM
Skeezer
You could probrably extend or relocate the tubes to a higher location, maybe someone who's done it before can give you some ideas. Good luck.
2005 Rubicon
Skeezer is offline
Water in the diff vent and trans?? wb2jte General Jeep & Off-Road Equipment 2 06-26-2009 11:15 PM
Tubes or no tubes? jerryjeeper General Jeep & Off-Road Equipment 4 05-03-2009 09:08 PM
Bass tubes in a TJ? Fuel Audio, CB & Ham Radios, GPS, & Electrical 13 06-23-2006 09:43 PM
Looking for a How to: Flatfenders w/ tubes Haik General Jeep & Off-Road Equipment 0 04-25-2006 11:18 AM
Bazooka Tubes? Black Hills TJ Audio, CB & Ham Radios, GPS, & Electrical 4 01-30-2006 11:37 AM
