Diff cross pin not fitting... grind teeth or wrong parts? - JeepForum.com
post #1 of 4 Old 06-08-2014, 04:24 PM Thread Starter
eduardostewart
Hi guys,
can't seem to find a definite answer on google. seen that it's not uncommon to have to grind a bit off the teeth to clear a pin. i have a 98 TJ, going from stock 3.07 to 4.56
i ordered the all yukon parts, new carrier to accommodate the higher tier of gearing and ring/pinion.
my question is, can any of you tell me if perhaps yukon sent me the wrong stuff in the packages or does it look correct and that i just need to grind some teeth? The ring does look a little fat, but not really thick, thick gear...
eduardostewart is offline
post #2 of 4 Old 06-08-2014, 07:00 PM
lar308
Install the side gears and spiders/locker then install ring gear, Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #3 of 4 Old 06-08-2014, 08:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2. A lot of guys grind a bit off the heel, but I seriously dislike that resolution.
jeepdaddy2000 is offline
post #4 of 4 Old 06-20-2014, 07:54 AM Thread Starter
eduardostewart
thanks guys, duh moment. not a c-clip axle so no worries.
