diagnosis 2.5 - JeepForum.com
post #1 of 2 Old 07-19-2007, 10:40 PM Thread Starter
ErikJordan
Pimp Hand
ErikJordan's Avatar
diagnosis 2.5
1988 yj 2.5 TBI
this thing has been trouble free for a long time, now i have a problem i cant figure out.
it was pulled into the driveway a bit sluggish, so my wife left it and took the truck to work.
i went out to see what was wrong with it, assuming she ran it out of gas again.
it started right up for me, but the ildle roared to about 2800 and stayed there.
it appears that the Idle Speed Actuator (isa) is keepng it there.
i figure, pull the plug and it will let off, right? NO.
i commence to pulling plugs on the rest of the crap that is on the throttle body, and there is no change.
this damn thing still roars at 2800 rpm.
so i put them all back... no change.
any thoughts on this thing?
there are no vacuum leaks that i hear or see.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #2 of 2 Old 07-21-2007, 09:21 AM
jadams68
jadams68's Avatar
Not seeing or hearing the leak doesn't mean you don't have one at the manifold.
If it were me, I'd find a local shop that has a "vacuteck" or "smoke machine" that they hook to your intake and blow smoke through the engine...where you see smoke, you have a vacuum leak. It will atleast give you peace of mind. The other thing may be the Idle Actuator like you mentioned.
Is the check engine light on?
Originally Posted by NAILER341
1988 yj 2.5 TBI
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
Need your Tranny noise diagnosis expertise!! smokedog Engines & Drivetrain 0 11-26-2008 07:07 PM
Fast Blinker - diagnosis? Bethlehem Audio, CB & Ham Radios, GPS, & Electrical 7 11-11-2005 05:37 PM
Auto X-ray Diagnosis? ErikJordan Engines & Drivetrain 1 07-21-2003 11:47 PM
Spark plug diagnosis needed... FunkSkunk Engines & Drivetrain 6 02-19-2003 09:28 PM
Where would you begin your diagnosis? mrusso Engines & Drivetrain 3 02-09-2003 09:06 PM
